help
Old Apr 21, 2007 | 09:00 AM
ptanner3's Avatar
ptanner3
help
truck was running, bumped some wires that i was messing with that are connected to the ignition wire, truck died, won't start, no dash lights when key is on ignition. truck turns over. ideas?
Old Apr 21, 2007 | 09:08 AM
STROKER350's Avatar
STROKER350
If it isn't a wire knocked loose, check your fuses. Hope you get if going.
Stroker350
Kingtim7's Avatar
Kingtim7
You probably shorted something. Check all wires you were messing with and then check fuses.
Old Apr 21, 2007 | 09:14 AM
Don Tim's Avatar
Don Tim
Wires under hood or under dash? Be SURE to pull the fuses and check- Sometimes they look good and you dont catch em the first time. Dhooooo did that !
Old Apr 21, 2007 | 09:35 AM
ptanner3's Avatar
ptanner3
found new twist in prob, when key is turned back to accessory radio and windows don't work. checked all fuses with light and showed fine
Old Apr 21, 2007 | 09:41 AM
Kingtim7's Avatar
Kingtim7
What wires were you messing with and why?
Old Apr 21, 2007 | 09:45 AM
ptanner3's Avatar
ptanner3
for a couple weeks been trying to get some switches for lights and turbo timer hooked up. been having trouble getting turbo timer to work so do not have the switches properly shoved under dash. set something on wires and slid it and seemed to have shorted out. unhooked them and checked fuses but no luck
Old Apr 21, 2007 | 09:51 AM
Uzumati's Avatar
Uzumati
1. What exact wires were you messing with (Color and system if you know)
Could have shorted the VSM but need to trace those wires to see what system they are tied to, could be something as simple as a broken wire in the column harness. Is it a manual or Auto Tranny?
Old Apr 21, 2007 | 10:11 AM
ptanner3's Avatar
ptanner3
have an '02 w/ auto. the hot wire for the switches were coming out of the fuse panel with a pre-existing connector that pulls power from the spade of a fuse. the turbo saver was pulling power from a switch which was pulling power from the cigar lighter and was also connected to the red and yellow wires off of the pyro, and also to the ignition wire, which is where the gauges are pulling there juice.
what is a vsm, and would that make the power windows and radio not come on when the key is on accessory. it just seems so much like a fuse but i pulled every one of those little pigs and were all okay. could it be a relay?
Old Apr 21, 2007 | 10:35 AM
ptanner3's Avatar
ptanner3
2 ?s. i read there are no fuses under hood of an 02, is that correct.
and when the cps goes does it cause all of the dash to not light up?
Old Apr 21, 2007 | 11:05 AM
Don Tim's Avatar
Don Tim
Not sure on the 02, Just pop the hood and look on the drivers side near the steering column, should be a fuse box there with the relays and larger fuses. Still sounds like a blown fuse to me.
Old Apr 21, 2007 | 11:11 AM
ptanner3's Avatar
ptanner3
yeah, me too. i looked under hood and there was little boxes about 3 1/2" square but not a big one like in my '93 bronco. know how i can test relays?
Old Apr 21, 2007 | 11:23 AM
ptanner3's Avatar
ptanner3
want to thank all that helped. ended up being one of the pink tall fuses that didn't look blown, but evidently was bad so replaced. thanks for all the responses. it lives!!!
Old Apr 21, 2007 | 11:28 AM
Don Tim's Avatar
Don Tim
Was it under the hood? told ya to look close. HAHAHAHA Glad you found it.
cts1954
Mar 11, 2013 03:01 PM
dn29626
Jul 17, 2011 08:40 AM
jonny cash truck
Nov 10, 2006 07:07 PM
mitchw32
Jan 31, 2005 08:21 PM
jasonbridges
Electrical Systems/Wiring
Jul 24, 2003 02:37 PM
