Strange Vibration
Old Apr 21, 2007 | 08:34 AM
flyingcouch's Avatar
flyingcouch
Strange Vibration
I just started getting a strange vibration from the front of the truck. It only does it while the truck is idleing after it is warmed up / driven for about 5 min. It seems to be related to the brakes. It starts and stops with pressure on the brake. It also seems to be somewhat intermitant.
2002 PSD Automatic, 6" lift, 4 MBRP, DP Tuner, ITP boost reg, 6637,
Old Apr 21, 2007 | 09:15 AM
STROKER350's Avatar
STROKER350
Mine did the same thing. Turned out the brakes needed replacing and the rotors were turned, too. Solved the problem for me. Hope that helps you.
Stroker350
Old Apr 21, 2007 | 09:46 AM
flyingcouch
It is not related to actually stopping, but after I am stopped and sitting without moving, with my foot on the brake.
Old Apr 21, 2007 | 09:58 AM
John311t's Avatar
John311t
Check your power steering fluid. My truck had that problem and made wierd noises, and since these trucks use hydroboost, you need PS fluid.
Old Apr 21, 2007 | 10:00 AM
Uzumati's Avatar
Uzumati
Check the power steering pump and the Hydrobost. the brake pedal is attached to the Hydroboost assembly.
Old Apr 21, 2007 | 10:40 AM
Kwikkordead's Avatar
Kwikkordead
Welcome to FTE flyingcouch. I like the name you have chosen. Lot's of room for boyhood dreams.
I agree on the hydraulic system problems. If the level is up, then you could try moving the steering side to side and see if you can duplicate the problem. That would point toward the pump itself as it has to build more pressure to move the wheels at the command of the steering input. You may have to turn the steering all the way to the left or the right to the stop where the pressure is the highest to get it to do it.
No vibration while turning the steering, then it points to the hydroboost itself.
Old Apr 21, 2007 | 09:15 PM
flyingcouch
Thanks for the help, I have been reading here for some time. I have learned a lot here.
The fluid level is good, and it does not seem to do it with steering wheel going to limits. What is involved with check / fix / change the hydroboost
How do I give myself a signature on the bottom of my posts?
Old Apr 21, 2007 | 09:29 PM
Uzumati's Avatar
Uzumati
Brake Booster
With the transmission in NEUTRAL and the engine stopped, apply the brakes several times to exhaust the vacuum in the vacuum boost system or the pressure in the Hydro-Boost system.
Hold the brake pedal in the applied position.
Start the engine.
If the power brake system is functioning properly, the brake pedal can be felt to move downward after the engine starts.
Accumulator, Hydro-Boost Only
Start and run the engine.
Stop the engine.
Apply the brakes. The accumulator in the Hydro-Boost power brake booster should retain enough pressure for at least two power assisted brake operations. If no power assist is felt, replace the Hydro-Boost power brake booster and retest the system.
Goto "user CP" (above the Post Reply Button at the top) and click on the Edit signature link on the left - I think you have to have a 25 post count minimum though.
Old Apr 22, 2007 | 08:41 PM
jrf250's Avatar
jrf250
Hello Everybody: Flyingcouch, I am a newperson here alao. Glad to here somebody else is having the same problem that I have. Mine just started last week after replacing the belt. I have norred it down to powersteering or break booster, fluid is full.
Thanks for the information Kwikkordead and Amiller93 going to try that tomorrow and see what happens.
Will write in with what I find out
Thanks
Old Apr 22, 2007 | 08:48 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Welcome aboard jrf250. Good luck and someone is usually here just about 24-7, but you know how it is in the wee hours.
Old May 4, 2007 | 12:22 PM
Redsundevil's Avatar
Redsundevil
Hey guys, need to dig up this thread again. I'm having the same problem as mentioned above.
At idle I can feel and here a grinding/vibration in what appears to be the power steering pump. Turning the steering wheel will make it change tones or go away, and increasing engine RPM's will make it go away as far as I can tell. The PS fluid level is good and I have no leaks. Further, the steering and brakes work fine, but his grinding is very disconcerting.
Has anyone else experienced AND FIXED this problem? If so, what did you have to do to alleviate the problem?
Thanks,
Jeff
