header paint
Old Apr 21, 2007 | 02:24 AM
ryan f150 4x4's Avatar
ryan f150 4x4
Question header paint
what paint do you guys use on headers
Old Apr 21, 2007 | 10:48 AM
dixiemudder04's Avatar
dixiemudder04
i used the 1500* paint and it still burnt off. Unless u get them ceramic coated i dont think paint with stay of them very long.
Old Apr 21, 2007 | 12:59 PM
53fatfndr's Avatar
53fatfndr
I've used high-temp exhaust paint and it peeled off as well. I then tried barbeque paint and it has not peeled off at all. I've used it on the two-stroke exhausts on my snowmobiles and the headers on my 400 in my '53. The barbeque paint has worked with no problems. Good preperation is a must for whatever you use
Old Apr 21, 2007 | 04:17 PM
Indy_Gearhead71's Avatar
Indy_Gearhead71
I was going to suggest bbq black as well. Even the high temp engine paints aren't really meant for headers, they claim 1500 but being a coating, they don't work as well. Bbq black is almost like a black etch primer in a way, it eats itself into the metal making it more durable. I'm assuming that since you want to paint them you're not wanting to spend the money on a set of ceramic coated, or Jet Hot coatings either.
Old Apr 21, 2007 | 10:15 PM
rsylvstr's Avatar
rsylvstr
duplicolor has a paint supposedly meant for headers and is "with ceramic" but only rated to 1200*.....intermittently.
Both Engine Enamel and High Heat Paint formulas now contain ceramic resins for maximum heat dissipation and gloss retention. The resins also offer protection from exposure to excessive heat and automotive fluids. Developed and tested in the lab, Dupli-Color® Engine and High Heat Paints will perform to the most rigorous standards of racing and street rod enthusiasts.
Dupli-Color® High Heat Paint with Ceramic
Old Apr 27, 2007 | 07:02 PM
JBradley500's Avatar
JBradley500
if you dont care which color they are you can use the high temp white. for some reason it seems to be the best for longevity. the way to apply it so it will stay is to take a torch and get the headers nice and warm then spray a good coat of the paint on it.
Old Apr 28, 2007 | 03:10 AM
roger dowty's Avatar
roger dowty
paint inside and out- so you will want to clean the inside with some sort of aggressive detergent and then I'd soak rags with ospo acid to etch it real good then maybe use the bbq stuff on a rspongeand push-pull through a couple/4 coats. headers often rust from the inside out.
Old Apr 28, 2007 | 05:43 AM
dixiemudder04
i wished i would have used some of that paint like the bbg paint, but in ford blue. I painted my new motor and its still blue but some rust is starting to come through. It could also be that the mud dried on it and caused it. How much does that bbg usually run??
Old Apr 28, 2007 | 02:14 PM
53fatfndr's Avatar
53fatfndr
I think I got mine at Lowe's for around $4 a can.
Old Apr 29, 2007 | 06:22 AM
5851a's Avatar
5851a
I have heard that John Deere muffler paint from the dealer is very durable.
Old Apr 29, 2007 | 01:02 PM
brucewolff's Avatar
brucewolff
The duplicolor ceramic paint worked well for me. It's best if you apply these high temp paints to a scuffed or better yet sandblasted finish.
Old Apr 29, 2007 | 11:27 PM
roger dowty
and no primer first...
Old Apr 30, 2007 | 10:27 AM
ryan f150 4x4
Talking
thanks guys the hooker supercomo. look great . first i cleaned them out with seafoam and bottal brush sandblasted them then heated them a used duplicolor
4 coats in and out thay look great thanks again
Old Apr 30, 2007 | 05:17 PM
dffay's Avatar
dffay
Are you guys heating the headers up after the paint is applied? it seems most of the paint companies recommend that as part of the curing process. I crank mine up but I don't bring them up to full temp too soon in the drying/curing process. They
Old Apr 30, 2007 | 05:19 PM
dffay's Avatar
dffay
seem to hold the temp better that way.
