i bought a 1995 ford f150 with a 302 and auto trans. the guy i got it from sold the computer from it so i bought one from a scrap yard. my problem is it starts and dies . i tried it several times and always the same thing it just starts and dies.......anyone have any ideas what to look for? thanks
What was the computer out of?
Is the Program Code on the computer "HUG2"?
As you can see from the list the part number that they should have gave you was:
F4TF-12A650-BBB but I think a postfix of BBA & BBC would also work.
Did the old owner say why he parked it and what it was doing then?
You may also want to check the fuel pressure by grounding pin#6 of the test connector with the key on, not running with a pressure gauge on the fuel manifold.
Also check the timing, pull out the SPOUT and to see if it will start and stay running. It may be shutting down when you leave base timing as somebody may have timed it wrong. It should be 10* BTDC with the SPOUT out.
i checked the computer and the number is f4tf-12a650-bbc and the code is bug2 i did read it right earlier.....according to the info mine is supposed to be bbb on the end of the part number
Yes it was a BBB when the truck was new.
I did see on one of the computer reseller list that a BBA or BBC will also work but Ford listed it as BBB.
