Modular V10 (6.8l)
Engine rattling at shift points
Old Apr 20, 2007 | 12:55 AM
Sundance Kid's Avatar
Sundance Kid
Unhappy Engine rattling at shift points
It's a 99 F-350 with 150,000 and auto tranny. If I accelerate hard I get a Rattling, ticking or pinging (?) at the point when the tranny gets ready to shift. It does it hot or cold. high or low octane gas. It doesnt matter if I'm pulling a load or not. What does matter is if I accelerate easy and not rev it high it will not do it. It's done this since I got it at around 135,000 miles. I'm leaning towards problems in the valve train or exhaust leak but not 100 percent sure. You have helped me in the past and I could sure use it again. Thanks
Old Apr 20, 2007 | 05:43 AM
FortyFords's Avatar
FortyFords
chk the heat sheilds on the exhaust system
chk the inspection cover on the front of the trans by torque converter.
chk for broken exhaust manifold bolts also
These are common noise producers
Rich
Old Apr 20, 2007 | 10:49 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Like Rich said, sounds like exhaust heat shields or the bellhousing cover - although the last one usually does it at 1700-2200RPMs, but anything's possible.
I'd also check the serpentine belt, and the fan clutch. Weird noises during shifts can be a bunch of things. Check your motor mounts And u-joints, even... unless you KNOW it's coming from up-front.
Schnurrbart
28
Mar 11, 2017 07:55 PM
Connecticut Calvin
29
Jul 15, 2016 09:10 PM
IdahoB
16
Nov 9, 2015 02:51 PM
catbones
1997 - 2003 F150
Mar 1, 2015 06:33 PM
ronjeremy6
Dec 31, 2013 07:20 PM
