Starter Going?
Old Apr 19, 2007 | 11:54 PM
Stroked Out!'s Avatar
Stroked Out!
Starter Going?
I Have A 03 6.0 And Yesterday It Turned Over But Didnt Fire Had To Try It A Second Time And The It Made A Starting Grind After Turning It Back On In The Drive Thru Is My Starter Going Out It Only Has 64000 On It?
Old Apr 20, 2007 | 12:29 AM
Snowbunny's Avatar
Snowbunny
The bendix gets weak and either won't stay engaged or won't come off the flywheel, either will cause a grinding noise. If you take it off and run it over to Napa or Ford, they can put it on a tester and let you know if the bendix is weak. You can replace just the bendix if you are so inclined. My re-man cost $280.00~
Old Apr 20, 2007 | 07:05 AM
BowTieHatr's Avatar
BowTieHatr
if it cranks the truck fine roll on. probably the starter never actually stop spinning before you tried it again.
Old Apr 20, 2007 | 12:57 PM
hott-rodd's Avatar
hott-rodd
If it happens again check to make sure the starter is tight.
