1978 - 1996 Big Bronco
78 Bronco Dashboard
Old Oct 9, 2001 | 04:29 PM
mikebert60's Avatar
mikebert60
78 Bronco Dashboard
I need to access the lone speaker in the dashboard in my 78 Bronco. How to I take off the part of the dash that I need to take off? ;-) Or does it all come off together?
I've tried taking out the few screws up near the windshield, and I took out the glovebox trying to get to the wiring for the speaker / radio antenna, for the record.
Thx 2 million for any help! =)
A 19 yr. old novice who
dreams of being a Ford pro,
Mike W.
Old Oct 9, 2001 | 08:54 PM
chaser's Avatar
chaser
78 Bronco Dashboard
Had a wonderful '78 and should know exactly what to tell you but, I can't!
I would suggest that you will have to get to the speaker by removing the radio first and probably working from under the dash. If I remember correctly I just cut the wires loose to the dash speaker and mounted speakers on either side of the body behind the front seats. (Right in that big metal panel)
Good luck, you've got a good start.
Old Oct 10, 2001 | 02:31 AM
mikebert60's Avatar
mikebert60
78 Bronco Dashboard
Thx for the support! =)
I kind of just got mean with it and grabbed the speaker from way over by the glovebox area and pulled it over to where I could work with it. (thx to Ford for puttting enough wiring to the speaker to allow for this)
Turns out the speaker is blown and needs a replacement... the stock '78 radio still works! Now all I need is to mount a CD player / cassette deck along with a CB radio underneath the dash by the gear shifter and I'll be set!
Mike W.
Old Oct 22, 2001 | 02:42 PM
Redbob's Avatar
Redbob
78 Bronco Dashboard
Mike:
You pull out the radio and work through that opening to get to the center dash speaker. Helps to have some really short screw-drivers, as I recall.
Old Oct 23, 2001 | 02:32 AM
mikebert60's Avatar
mikebert60
78 Bronco Dashboard
How do I go about pulling out the radio? =)
Old Oct 23, 2001 | 06:47 PM
Mil1ion's Avatar
Mil1ion
78 Bronco Dashboard
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bd6019b56fa9b7a.gif
Would you care for a Jpeg file of HOW TO R & R a radio and speaker from the Shop Manual?
Dennis
78 F-150 429CJ 465,000 KM.(Original Owner)
68 Mustang 289 Sunlit Gold 80,000 Miles(second Owner)
64 1/2,260 Pre-World's Fair Mustang #8092
64 Fairlane 500 S/C,waiting for a 390 4-Spd
If The Girls Don't Find You Handsome,
They Should At Least Find You Handy!
Old Oct 24, 2001 | 12:40 AM
mikebert60's Avatar
mikebert60
78 Bronco Dashboard
Yes, that would be a great help! Although I know I ought to really put priority to saving up a little bit and just buying a shop manual (although I've bought 2 others for other Fords and every time I figure out most of it without it).
My e-mail is mikebert60@home.com if you want to send it there or let me know what you would like to do!
MW
Old Oct 24, 2001 | 09:48 AM
thelonerangerxlt's Avatar
thelonerangerxlt
78 Bronco Dashboard
jd58980
Jun 11, 2011 03:34 PM
Rusty_S
General Automotive Discussion
Dec 14, 2010 12:56 PM
oem78
25
Apr 10, 2006 11:05 AM
crash_b
Bronco II
Sep 22, 2003 08:50 PM
JBronco
Oct 5, 2002 03:31 PM
