Grinding After Engine Dying
Old Apr 19, 2007 | 08:06 PM
F15075's Avatar
F15075
I Have A 06 F150 4x4 And Today My Engine Died Going Down The Road. I Was Letting In Come To A Stop Before Restarting And Something In Engine Area Starting Grinding Loud. Any Ideas What That May Have Been?
Old Apr 19, 2007 | 08:12 PM
06fx4md's Avatar
06fx4md
See the post "F150 Grinding Noise" further down, it may be related.
Colin
Old Apr 19, 2007 | 08:50 PM
Tom's Avatar
Tom
It was your front hubs trying to lock in 4x4...had a similar thing happen to me...
Your hubs are spring loaded, and whenever there is no vacuum applied to them from the engine, they are going to lock into 4x4. When the truck is parked, with the engine off, your hubs are locked. When you start the engine, and the truck is in 2HI, vacuum solenoids apply vacuum to the hubs, and they release. When your engine died, all of the sudden there was no vacuum going to those hubs. This caused the springs to lock the hubs, but while this was happening the front drive shaft was still locked at the t-case.
So, they were trying to lock in, but couldn't because the truck was moving and the driveshaft was locked. This was the grinding you heard. Nothing to worry about with the grinding...but why did the engine die?
If this happens in the future, hit the brakes ASAP to avoid this, as over time it will damage your hubs. If you can't hit the brakes, engage your 4x4, which will unlock the driveshaft and spin the front driveline up to speed, and allow the hubs to lock in without damaging themselves.
Old Apr 19, 2007 | 09:04 PM
4getfulbj's Avatar
4getfulbj
i have an 04 xlt 4x4 scab. and my does the same thing but my engine doesnt die. could the front differential fluid have anything to do with it? the fluid is gray. just waitin on next pay day to change fluid.
