fuel filter disconnect
Old Apr 19, 2007 | 04:21 PM
purpleford's Avatar
purpleford
anyone what size tool to use to disconnect the fuel filter on a 97 exp. 5.4?
thanks!
Old Apr 19, 2007 | 04:46 PM
FTE Herman's Avatar
FTE Herman
Do you have the color coded line tools? If I recall, it is the white one, but I haven't done it in a while.
Old Apr 19, 2007 | 08:18 PM
2000Expy's Avatar
2000Expy
The filter is underneath right? Well it is on mine. I use a aluminum scissors like tool from NAPA.
Old Apr 19, 2007 | 08:37 PM
kwegman003's Avatar
kwegman003
i believe it is 5/16th
thats what it was for my1997 4.6l and i assume its the same. I was given the wrong one at the parts store and spent an hour yanking then i went back and picked the smallest one. good luck i think its the 5/16
Old Apr 19, 2007 | 08:51 PM
purpleford's Avatar
purpleford
thanks! It is 5/16 After a little work I got it disconnected.
Helpful hint: blow out the debris that has collected in the fitting and the disconnect will be easier
Old Apr 20, 2007 | 08:23 AM
MisterCMK's Avatar
MisterCMK
Those spring lock disconnects are always tricky. The color coded tools help a LOT. I finally picked those up after doing a bunch of AC work on my Explorer this summer.
Old Apr 20, 2007 | 09:11 AM
sysman_rick's Avatar
sysman_rick
Spring lock tools will not work on the fuel filter.
