Has this one been asked?
I have a 408(scat stroked 351c) supercharged to 4psi with an eaton M112 blower, in my 84 bronco.
its on straight LPG (propane to u yanks
), fed by 2 x GRA 400 CFM carbies.and im thinking nitrous. after researching nitrous oxide, it seems to be a match made in heaven. i have a spacious post-boost intake manifold, just achng for some nitrous foggers/injectors. will it work? will it have to be a 'dry' system?
my engine's internals are pretty strong. Scat rods & crank, probe pistons, 8.5:1 comp, solid lifters, alloy 2v AFR heads.. all with less than 5k on the engine.
(engine link http://www.airflowdynamics.com.au/Pr...ngine_408c.htm )
- Sean
I would just up the boost to 8 or 10 PSI.
But if you get a nitrous kit it's best to run a wet kit. and make sure your fuel pump or pumps is up to handle the extra HP.
however I like my engine reliable, and low boost & low comp is very good for this... that and the eaton M112 is redlining at 4psi when my truck does 4500rpm, so it would require another, larger, supercharger... and eaton doesnt make them any bigger :/
the truck storms around the roads really well, and I cannot fault it, however if I ever see that AMG suv again I'd like to give it a surprise, nitrous style...
thought I'm wondering which would be cheaper/wiser.. complete nitrous kit, installed... or 4.11 gears.
-Sean
Stock Lightning comes with a M112 and 8# of boost from the factory. Guys on the Lightning site are running them a 15 PSI.
I used to run a M90 at 10 &1/2 PSI
With your low compression you would have no problems running more boost.
If your trying to decide on gears or nitrous. With the gears you'll have the extra power all the time.With the nitrous you have to keep filling the bottle.
this is the technical stuff, which will explain why i cant run more boost on this charger;
the M112 unit I have redlines at 12,000rpm, I am running a 2.6 inch charger pulley and a 6 inch crank pulley, (which gives 2.3:1 ratio, for every 1 rotation of the crank, the supercharger rotates 2.3 times)
the charger puts out 1.84 litres of air each rotation... (maths maths calculations) *whazzam* this all means at 4500 engine rpm (my rev limiter) my M112 is doing 10384 rpm (close enough to redline for me)
.: running higher boosts means breaching my chargers redline, thus my desire for nitrous.. and/or lower gear ratio.
but I'll be damned if 4.11 x 2 (4wd) isnt expensive over here in Australia
anyone wanna ship it over for me? I'll pay, of course
So, giggle gas huh?
You have to be careful you don't lean out... if you want to install a dry system that is.
What I think would be a good idea is have a supplentary propane injection system... like what a lot of diesels have, so when you "flick the switch" on your nitrous, you can still have enough fuel.
And your Bronco is your daily driver isn't it? I personally don't like lower gears, on anything that you want to drive out the gate at the track. But thats a personal thing, I like to have an engine idling while cruising at 60
A dry kit is either sprayed through the MAF and uses that to add the extra fuel or it is sprayed post MAF and bumps the fuel pressure up. Either way is fine, just make sure you throw a wideband on it, especially since you are supercharged. A wideband, Mallory 685 (which also has can accept a MAP sensor for boost timing retard), FPSS and some conservative tuning will go a long way in having a reliable setup.
