Sponsored by: Real Truck
Wheel adapters/spacers
Old Apr 18, 2007 | 10:15 PM
Benny2002's Avatar
Benny2002
Question Wheel adapters/spacers
I was wondering if any fellow FTEs are running wheel spacers or adapters? I have a problem with my new 37s rubbing on leaf springs in tight corners, i know the little tricks to do with the steering stops but that 1/2 is huge in parking lots Any input?
Old Apr 18, 2007 | 10:45 PM
travis dasher's Avatar
travis dasher
I have the same problem my tires are 36x15.50. I am going to follow this thread and what the replies are.
Old Apr 18, 2007 | 11:32 PM
99f350sd's Avatar
99f350sd
I wouldn't do anything like that because you are already gonna over stress the hub bearings with those meaty tires..Now if you had the dynatrac kit installed that would be a maybe or even yes because of the older style bearing design and space between the bearings and load capacity. If I were you guy's I would do that kit in a heartbeat..
http://www.dynatrac.com/products_freespin_ford.html
Give them a call see what they say about adapters with their kits..
Dick
Old Apr 19, 2007 | 12:12 AM
RACERX7775's Avatar
RACERX7775
holy crap... $1800 thats alot. i can buy 4 sets, yes sets, of front hub bearing assemblies for that...you can just swap the hubs to the manuall hubs too.
Old Apr 19, 2007 | 08:15 AM
99f350sd's Avatar
99f350sd
Better than your wheel falling off at an intersection LOL. Think how all the chebby guy's will talk when this big monster tire comes rolling past there truck.
Old Apr 19, 2007 | 09:39 PM
RACERX7775's Avatar
RACERX7775
well, my X will never see off road. thats what my dodge is for...see gallery. and i already have new bearing assemblies on mine. i think the dynatrac kit is for the person who plans to do some moderate to heavy wheelin. not me..if i had the $$$$under the mattress, then yup, i'd do it..
Old Apr 19, 2007 | 09:59 PM
99f350sd's Avatar
99f350sd
The big tires can kill bearings in as little as 10k miles on the road..
Dick
Old Apr 19, 2007 | 10:04 PM
Benny2002's Avatar
Benny2002
Racer? Are you running adapters?
Old Apr 19, 2007 | 10:16 PM
RACERX7775's Avatar
RACERX7775
no sir. i get the correct offset for whatever truck i buy wheels for. there are some wheel spacers out there that are meant to be abused because they can tak it. they are made from billet alum. and my wheels and tires aren't that big to need them.
Old Apr 19, 2007 | 10:18 PM
Benny2002's Avatar
Benny2002
Do you know anyone running them? Ive seen those ones and they look stout enough, i was just trying to get some feedback from someone whos had them, or can attest to their strength
Old Apr 19, 2007 | 10:34 PM
oldkountryboy's Avatar
oldkountryboy
i have a set of 2" spacers sitting in the garage waiting to go on, going to install them next week when i do my ball joints
i have talked to several people who have run them with no problem
if you get the spacers that just push the wheel out you wil have a problem keeping your lugs tight, if you go with an 1.5" spacer that bolts to the hub and you wheel bolts to it then you have to cut your stock studs off shorter, not good
that is why i went with the 2" billet spacer bolt them on with some lock tight and if i need to remove them later i can
Old Apr 19, 2007 | 10:43 PM
Benny2002's Avatar
Benny2002
where did you get them? How much
Old Apr 19, 2007 | 11:19 PM
oldkountryboy
i got mine from a friend who was selling his truck, we just swapped tires and wheels
they have them on ebay all the time for around 100 a pair for 2" spacers
Old Apr 19, 2007 | 11:35 PM
cam188's Avatar
cam188
I am running a 1/4" spacer which is just enough to offset the tire. so it only rubs at full lock a tiny bit on the leaf. I don't think I would go any bigger than 1/2" top
37" on Mickey Thompson Classic locks 17x9
JMO.
