Sponsored by: Real Truck
Packing front wheel bearings
Old Apr 18, 2007 | 07:36 PM
schwengler's Avatar
schwengler
Thumbs up Packing front wheel bearings
I have a 2002 F-250 4x4. Can anyone tell me if the front wheel bearing can be repacked. I was told they where a sealed unit. Thanks for any input.
Ray
2002 F-250 4x4, 4" exhaust, superchip, Ford AIS, Zoodad mod.
Old Apr 18, 2007 | 07:51 PM
FortyFords's Avatar
FortyFords
They are a sealed unit no packing ,but there is a set of needle bearings that should be greased and packed every so often .They support your 4x4 axle shafts.
They are located as part of the sealed unit.
Rich
Old Apr 18, 2007 | 07:55 PM
sandmaniac's Avatar
sandmaniac
Pack or Not
Schwenger, I have '99 250 SD, just chased down the grinding noise in my front-end. I tore apart my hubs, it was a fairly simple task. As soon as I pulled the hub assem, my inner needle bearings fell out on the ground. So, packing wasn't an option. I did replace that side with a new one, ( Checker Auto, 275.00, non- ABS ) and cleaned up the other. The failed bearing was a result of the previous owner not replacing the big yellow " O-ring ", very inportant! My front hubs weren't ABS equipped, so about half the cost.
So, if the bearings show any signs of wear, I would replace it. Cheap insurance down the road.
Old Apr 18, 2007 | 08:04 PM
FortyFords's Avatar
FortyFords
Sandmaniac,the little yellow o-ring does little to keep the moisture out of the needle bearings.
The large knuckle seal is the culprit that causes all the grief in our 4x4 setups on Dana 50/60 front ends.
The water comes in from the backside of the knuckle
Rich
Old Apr 18, 2007 | 09:39 PM
lowet's Avatar
lowet
Yes the large funky Knuckle seal that is in the back of the knuckle, sombody at Dana needs to get SHOT in their foot for this design.
Old Apr 19, 2007 | 03:23 AM
wlihntr's Avatar
wlihntr
here ya go..thanks Guzzle: http://guzzle.rbmicro.com/nblube.html
Old Apr 19, 2007 | 07:27 AM
Bowstring's Avatar
Bowstring
Looking at Guzzles site on packing needle bearings, If I don't have a vacuum gauge to test with ,whats the chance of having any leaks if one takes care when installing new o-rings and reinsembling?
Old Apr 19, 2007 | 08:00 AM
FortyFords's Avatar
FortyFords
Well at the dealer shop I worked at (since retired ) we had no problems after replacing o-rings an seals.
A big thing to look at is if the sealing surface that the o-ring or seal is trying to seal against is pitted with rust or a groove worn in it,Replace the part.
use grease on installation of these seals as recommended also.
Its not a requirement to chk vacuum.
if parts are worn replace them.
Rich
Old Apr 19, 2007 | 08:39 PM
schwengler's Avatar
schwengler
Thanks for all the advice guys. I'm going to getter done this weekend.
Ray
2002 F-250 4x4, superchip, AIS, 4" exhaust, Zoodad mod.
