1/2 Ton Dually
Old Apr 18, 2007 | 02:44 PM
4fords's Avatar
4fords
1/2 Ton Dually
Has anyone converted their 1/2 ton to a dually rear? I've been thinking of doing this. I've also checked out some of the dually conversion kits but was thinking of just swapping my 9 inch out for a F350 dually rear. Anyone do this swap? My truck is a 85 F150 4x4 with a 351HO and C6. Any info is appreciated.
Thanks,
4fords
Old Apr 18, 2007 | 02:46 PM
seventyseven250's Avatar
seventyseven250
Are you doing this for looks or are you wanting to get more hauling capacity out of it? The amount of work you need to do will be determined by your goals for the build.
Old Apr 18, 2007 | 02:50 PM
4fords's Avatar
4fords
I'm thinking of the swap for both reasons. Get more load capacity and have something different.
Old Apr 18, 2007 | 02:53 PM
andym's Avatar
andym
You won't increase your payload or towing capacity by much with this swap. There is lots more that goes into how much a truck can safely haul than just number of wheels.
Frame strength and brakes are the two most overlooked areas. If you put 5000 lbs in the bed of a half ton, guess how well those single piston calipers are going to do stopping that load?
And you *will* fatigue your frame by overloading it.
Old Apr 18, 2007 | 02:57 PM
4fords's Avatar
4fords
I guess I meant that I would like better load managment. I'm thinking of putting a slide in camper in the box and pulling a trailer with 4 atvs. I know what you mean about overloading the brakes. I just did the brake system upgrade on my 76 last year. It made a world of difference.
Old Apr 18, 2007 | 02:58 PM
andym's Avatar
andym
I think a slide-in pulling 4 ATVs is going to be too much for a 1/2 ton truck.
Old Apr 19, 2007 | 11:46 PM
1982_f150's Avatar
1982_f150
i know a guy who converted his 89 ranger 2wd to dually. he tows bobcats with it all the time.
ufvj217
Nov 29, 2015 02:40 AM
OneTonCamper
Dec 19, 2014 09:32 AM
defiantoutlaw
Mar 26, 2014 07:20 PM
OLDSOUL67
28
Sep 11, 2006 10:36 PM
captgarysr1
Mar 22, 2006 08:47 AM
