Grill
Old Apr 12, 2007 | 09:06 AM
Hercmech's Avatar
Hercmech
Grill
Hey,
Will a grill from a 87 and up F150, "FIT" on a 80-86?
Thanks
Old Apr 12, 2007 | 09:13 AM
hoxiii's Avatar
hoxiii
yes, if you put it on with the 87 up hood and fenders.
Justin
Old Apr 12, 2007 | 09:20 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
When the 1980 F Series and Bronco was introduced, there was no blue oval emblem on the grille. The blue oval emblem was first offered in 1983, and when that grille came out, Ford obsoleted the previous grilles (1980-82) and replaced them with the 83 type. So if your 1980-82 Bronco or F Series truck has the blue oval, the grille was replaced.
Old Apr 12, 2007 | 09:27 AM
hoxiii's Avatar
hoxiii
Yes, but how does that relate to an 87?
Justin
Old Apr 12, 2007 | 09:40 AM
NavyMIDN08's Avatar
NavyMIDN08
in short, no, unless you swap out the whole front end, the grill will not fit correctly... the core supports aren't the same, the fenders and hood are different, and the grille is as well. you may be able to cut and massage the grille into kind-of sorta working, but it will look all wrong. you'd be best off to just get the correct grille. whether or not you get the blue oval or not is a personal choice depending on styling issues and whether or not its a "restoration" or a mod.
Old Apr 12, 2007 | 10:47 AM
Hercmech's Avatar
Hercmech
Thanks anyway. It was worth a try.
Old Apr 19, 2007 | 11:50 PM
1982_f150's Avatar
1982_f150
will a 92 grill fit on an 89 if i get the 92 headlights to??
