1978 - 1996 Big Bronco
hubs
Old Nov 4, 2001 | 10:05 PM
88BroncoXLT's Avatar
88BroncoXLT
hubs
On my 88 it has flanged hubs that go over the lug studs. Can I replace the hubs and rotors from a 77 F150. The parts books say that the rotors are the same but I do not know if I can change over to get away from the flanged hubs or not. Thanks for the help.
Old Nov 5, 2001 | 01:59 PM
honney's Avatar
honney
hubs
I'm thinking you'd be better off to find a TTB truck for the swap. I'm pretty sure you're gonna need everything from the knuckles out including the stub shaft. That is to say you won't need the knuckles, but you'll need stub shaft, spindle, wheel bearing hub, rotor. Not sure about the caliper. Wheel bearings for virtually any D44 are the same.
But the spindle on the '77 should be a 5-bolt design while you need 6 IIRC. And the stub shafts are different. Everything else will probably work - sorry I'm a little rusty on this info.
Old Nov 6, 2001 | 03:56 AM
chaser's Avatar
chaser
hubs
honney,
I have a posting over on the "4wd" listing about automatic hubs. You seem to be knowledgable about the subject - do you know the answer?
Thanks,
Old Nov 8, 2001 | 03:22 PM
sclemons's Avatar
sclemons
hubs
Yup.... new spindle, hub, stub shaft, locking hub, bearings. One of the flange style wheel bearings is the same as other years, but the other is not.
Old Nov 8, 2001 | 03:29 PM
sclemons's Avatar
sclemons
hubs
tommytorino
1997 - 2003 F150
Mar 27, 2011 09:00 AM
baverwolf
Dec 16, 2010 07:02 AM
klinkm
Feb 2, 2006 04:01 PM
Mattcin
Mar 14, 2005 05:07 PM
