No Cruise- HELP!!!
Old Apr 18, 2007 | 10:44 AM
scottie2hottie's Avatar
scottie2hottie
Question No Cruise- HELP!!!
Ok figured I'd start my own thread now since the problem persists....Changed out third brake light and checked fuse. What do ya'll think about my cruise??? Would really like to have it working.
96 F350 Diesel Crew Cab Dually Automatic 2wd
Old Apr 18, 2007 | 10:59 AM
quicklook2's Avatar
quicklook2
could be the cruise switch or clockspring.
what does 3rd brake light have to do with it?
Old Apr 18, 2007 | 11:17 AM
scottie2hottie
I just read on another post that if the third brakelight is burnt the cruise won't work....mine was so i tried it.
So the switch itself on the wheel? what's the clockspring?
Old Apr 18, 2007 | 11:24 AM
quicklook2's Avatar
quicklook2
the switch on the master cylinder, that has been recalled.
the clockspring is behind the wheel. the horn usually does not work either.
check fuse for cruise control.
Old Apr 18, 2007 | 12:23 PM
scottie2hottie
horn works, cruise fuse(lol) is good too. Should I just take my truck to a dealership to check the recall or is there a fix?
Old Apr 18, 2007 | 12:29 PM
scottie2hottie
just called ford- recall doesn't apply to my truck. That's based on the VIN so im sure that's fairly accurate.
Old Apr 18, 2007 | 12:48 PM
scottie2hottie
the service mgr there said to check the two-prong plug on the master cylinder to see if it was unplugged in lieu of the recall- he said a lot were incorrectly unplugged. i didn't see any 'two' prong plugs on the MC, only the three prong plug directly beneath the MC cap. what should i be looking for with this "switch plugin" hoopla?!?!
PS- i did find a plug- two pronged- unplugged from whatever it used to be plugged into, and wrapped in black tape. it looked rather mangled. altho there was no place to plug this 'plug' in on the master cyl, it looked like that was closed to the only place to plug it into- it had a short lead and was laying on the power distribution box. the only avail plug on the MC was still plugged in, the one directly below the mc cap, with three wires. on the very end of the MC on the top, there was a brass plug, that I thought looked strange. is that typical?
Old Apr 18, 2007 | 12:58 PM
scottie2hottie
I stole this quote from a diff thread
Originally Posted by Cuda_jim
Scottie, If replacing the 3rd B-light doesn't fix your CC, check the BPA (Brake Pedal Apply) switch on the front of the master cylinder. It's a normally closed switch, it opens when pressure is applied to the brake pedal. This switch is the subject of a recall that may cause a fire.
Does "closed" switch mean I can just splice the wires and be done with it? Only down fall being my cc won't shut off when the brakes are pressed?
Old Apr 18, 2007 | 01:08 PM
quicklook2's Avatar
quicklook2
go to ford have them look at it and tell you if you need to get that part and hook it up.
if it was not supposed to be unhooked because it was not part of the recall than it should work if you hook it back up.
Old Apr 18, 2007 | 01:41 PM
scottie2hottie
called em- the switch + pigtail only $20, think I'll go that route for now . Am I gonna have to re-bleed the brakes and all that after i install this?
Old Apr 18, 2007 | 01:56 PM
quicklook2's Avatar
quicklook2
probably not.
when you remove the old one have the new one right there.
Old Apr 18, 2007 | 02:05 PM
scottie2hottie
that leads me to yet another question (can you tell this is a new truck I'm not used to) how should the pedal feel on this truck vs my 01 v6 f150? the truck stops just fine(or seems to) but the pedal feels a little(not a lot) spongy. is that typical for a diesel? my buddy said his is the same so i wasn't overly worried about it.
