C6 to E4OD
Old Apr 17, 2007 | 06:47 PM
hsfbfan's Avatar
hsfbfan
C6 to E4OD
I have an '88 F150. It is a 351 4x4 with the C6 transmission. Shortly I'm going to put in a rebuilt engine. I am interested in swapping to an E4OD transmission. I know this transmission didn't come along until later years.
What would be the pros and cons of this swap?
What issues would be presented?
Old Apr 17, 2007 | 06:53 PM
flareside_thunder's Avatar
flareside_thunder
I have a 95 flareside and I WAS going to put in an E4OD4x4setup under it to convert it from 4x2.However, as I got to looking at it....Iwould have needed a new brain box the tranny wiring harnesses and 4x4 module located on the passenger side kickpanel...you may have more initiative than me but.....too much work and involvement for my blood.And, lessons be learned, I should have looked into that swap a little further before spendin a grand ona totaled bronco with a racing tranny in it.....now I'm stuck with it and trying to sell it.(any interests?????)......forless thanI paid.If I can think of anything else for this swap....I'll give ya a buzz.Thanks.
Old Apr 17, 2007 | 08:25 PM
mrl390's Avatar
mrl390
I believe that the E4OD is just the C6 with overdrive. Anyone confirm that? If this is true, it should bolt right up to stock mounting positions. I dont know if the bellhousings are the same but I believe they are. You will need a new computer and maybe a shorter drive shaft. Im not a transmission guy so dont take my word until you can confirm it with someone else who knows a little more than I do.
Old Apr 17, 2007 | 08:42 PM
jroehl's Avatar
jroehl
The bellhousings match, but the lengths, I believe, are different, so you'll need to change the driveaxle. The C6 is vacuum controlled, but the E4OD is computer controlled. There are aftermarket tranny control modules available, but they're spendy. Then there's the whole shift linkage/indicator issue.
Not impossible, just not a straight drop-in, either.
Jason
Old Apr 17, 2007 | 08:48 PM
andym's Avatar
andym
About the only benefit would be the addition of overdrive. The swap is a lot of work. You can pick up a computer from any 351/E4OD truck.
Also, a lot of the early E4OD's are weak. You want a late model one, 94 or later.
renchr56
1978 - 1996 Big Bronco
May 29, 2006 09:42 PM
AndysFords
Apr 2, 2006 08:40 PM
grimmson
Feb 13, 2005 06:25 AM
AmeriKen
Apr 25, 2004 02:16 PM
teajay
Apr 6, 2002 10:26 PM
