Check eng. Code 14
Old Apr 17, 2007 | 04:10 PM
99F150's Avatar
99F150
Check eng. Code 14
is code 14 on a 1987 Tbird Turbo Coupe the same as for a 87 RAnger with the 2.3?
MY Bird sored that code last week whe it was missing and the tach going spastic. scanner said pickup coil circuit failed.
Is that the star wheel in the distributer?
Thanks Dan
Old Apr 17, 2007 | 05:43 PM
sjwoody's Avatar
sjwoody
I'm not that familiar with that application, but the pickup coil (maybe called the PIP, or profile ignition pickup) should be the sensor that responds to the star wheel as it rotates. A book I have says the distributer must be removed before the coil can be replaced.
Old Apr 17, 2007 | 06:24 PM
Rockledge's Avatar
Rockledge
Along with the coil pickup, you should also suspect the TFI module, as well as the associated harness and connector.
See: www.asashop.org/autoinc/dec2002/techtotech.cfm
Old Apr 18, 2007 | 09:10 PM
99F150's Avatar
99F150
Thanks, I put a new TFI modual on last year. I took the distributer out today and replaced the PIP with a lifetime war. part from Borgwarner made by Standard ig parts. Ford wanted $68.00 vs $34 and Ford war. only 12 months 12,000 miles.
I hope this cures it as I take her on a 1000 mile run next week.
