Coolant overflow problem
Old Apr 17, 2007 | 01:36 PM
Hank130's Avatar
Hank130
Sry folks, too many pages to search, so I apoligize if this is already in a thread...
My problem:
-After about 15 mins of driving, the coolant spews out of the cap.
What I do know:
-Chem test was run for well over 30mins to check headers. Test came up negative.
-Cap was replaced.
-Waterpump has a small leak.
-Engine is not overheating.
I took the cap off with the truck idling. When I revved the engine, the coolant level dropped normally, and when I let off the pedal, the water "super" surged back up. Is there any other way of having these symptoms without bad head gaskets?
Thanks,
Hank
Old Apr 17, 2007 | 01:40 PM
Hank130's Avatar
Hank130
Ha, found the same exact problem on the second page.....go figure.
I'll still take any advice. My first course of action is to replace the water pump and thermostat.
Hank
Old Apr 17, 2007 | 05:45 PM
Ultramagdan's Avatar
Ultramagdan
Hello Hank and Welcome!
Glad you found a similar post. Sounds like you're on the right track. Let us know how it turns out.
Old Apr 17, 2007 | 05:58 PM
Steina's Avatar
Steina
CO River Rat
Hank -
One possibility is a pin-hole leak in the coolant recovery tank hose; the radiator forces coolant into the tank when warm, but pulls air back when cooling off because of the hose leak. If this is the problem, you always have air in the cooling system. Maybe the pump leak is allowing air in also.
Steve
Hank85713
Modular V10 (6.8l)
Jan 11, 2017 01:09 PM
Hank85713
Jun 25, 2016 12:18 PM
Hank85713
May 14, 2016 03:15 PM
RaulERichardson
27
Nov 4, 2013 12:36 PM
brdhouse6
Jun 29, 2011 01:24 PM
