need some help
Old Apr 28, 2007 | 04:41 PM
subford's Avatar
subford
Originally Posted by billsbeater
I posted my readings wrong its 7.5 volts at the inertia switch, when 6pin is grounded it reads 12.5 volts. I read that the power flows from the relay to the inertia switch then to the pump. If I'm getting the right volts at the inertia switch, what if I ran a new wire from there to the pump?
You would not be able to switch tanks.
Take a look at the selector switch on your dash, it may be bad.
Old Apr 29, 2007 | 06:58 PM
billsbeater's Avatar
billsbeater
Smile
I just wanted to let you guys know I got her running. Couldn't have done it with out you guys, My heart felt apreciation to all of you especially you Subford.
Old Apr 29, 2007 | 07:03 PM
LxMan1's Avatar
LxMan1
What did it end up being???
Old Apr 30, 2007 | 08:09 PM
billsbeater
I believe it was just a bad connection on the tank selecter switch, although I'm not entirely sure because at the same time I elimnated the enertia switch (temporaly) to make sure that wasn't the problem. I'm just relieved its running than anything. As long as there's no more problems down the road.
Jymmm
21
Apr 3, 2019 12:52 AM
84Ford250
15
Jan 22, 2015 09:13 PM
biffy626
Sep 10, 2008 07:56 PM
jamsx1
Oct 8, 2005 06:45 PM
joelaurenson
1983 - 2012 Ranger & B-Series
Feb 7, 2005 03:32 PM
