Sponsored by: Auxito
need gear ratio
Old Apr 16, 2007 | 10:39 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Hmmm...
https://www.ford-trucks.com/article/...r_Decoder.html
Old Apr 16, 2007 | 11:00 PM
LxMan1's Avatar
LxMan1
OOps, Brain fart. 22 must be for something else. Possibly 3.31 maybe?
Old Apr 17, 2007 | 11:20 AM
KingRanchMan02's Avatar
KingRanchMan02
Originally Posted by 99f15035/12.50/20
under axle it had a 26
Like LXMan said, code 26 is a 3.73 open axle.
Old Apr 20, 2007 | 02:52 PM
99f15035/12.50/20's Avatar
99f15035/12.50/20
well i tryed to look on the axle and i found 2 tags one with the oil and one with random numers and no ratio any help need to order new gear and need to know
Old Apr 20, 2007 | 08:54 PM
Fasterhorses's Avatar
Fasterhorses
Those random numbers are your ratio and gear dia. "355 975" would mean your gear ratio is 3.55 open diff with 9.75" dia ring gear and that is almost always the rear diff. If it's 3L55 then it has limited slip. The front tag should say 355 88 where the 88 means 8.8" dia ring gear.
Old Apr 20, 2007 | 10:51 PM
99f15035/12.50/20
here is the numbers 3 75 9 75 9a10 s 924 a
Old Apr 20, 2007 | 11:01 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Are you sure it says 3 75? There are no 3.75 gears available. Looks like you have 3.73's...
Old Apr 20, 2007 | 11:06 PM
99f15035/12.50/20
ya it was 3 i type wrong
Old Apr 23, 2007 | 10:54 AM
KingRanchMan02
Now you know that your door tag matches the axle tag.
Old May 25, 2007 | 01:23 AM
betontheturtle's Avatar
betontheturtle
going to hyjack your thread got 413B on my 01 excursion does that mean 410 gears??
thank for the use of the thread.
Old May 25, 2007 | 07:27 AM
liquid 1's Avatar
liquid 1
It looks theres a B2 in the tag picture, and lexman has posted thats a 3.73LS
Old May 25, 2007 | 11:44 AM
betontheturtle
and the axle code says C1. thanks again
Old May 25, 2007 | 12:55 PM
  #28
LxMan1's Avatar
LxMan1
C1 may be a 3.31LS. I haven't seen that one before.
Old May 26, 2007 | 12:14 AM
  #29
schmidty_dog's Avatar
schmidty_dog
If it hasn't been removed yet you should have a tag on your rear differential with info about the gears. It will be a stamped piece of metal that is attached with one of the bolts that hold the cover on. It should be pretty easy to read and figure out your ratio.
Old Jun 15, 2007 | 11:35 AM
  #30
focuszx3lover's Avatar
focuszx3lover
H9 is what is on my door what would be the gear ratio of that truck
