front end alignment
Old Apr 15, 2007 | 04:43 PM
mean91's Avatar
mean91
front end alignment
i'm new here but i have a 91 f-150 4x4 with a tough country 4 inch suspension lift all the way around and 35 inch tires. i have been havin problems with the front end seems like since i lifted it. i have adjusted it many times but it still seems to get out of line 1-2 times a year. i've done all i know to do. what can i do to make it stick permanently. all advice appriciated.
Old Apr 15, 2007 | 05:46 PM
t4kne's Avatar
t4kne
What is going out, caster, camber, toe in, out? Is it always the same?
Old Apr 18, 2007 | 05:31 PM
mean91's Avatar
mean91
it's toeing in at the top(THIS TIME). no, it's never the same. it will toe in and out i put new camber bushings in it not even a year ago so that shouldn't be the problem.
Old Apr 18, 2007 | 09:30 PM
351slug's Avatar
351slug
How much toe in are you running. If you have too much you will see the camber change when you back up , then correct itself when you pull fowards. 0 to 1/8 inch is spec. Make sure your lift kit is still tourqed down. Check cross member for cracks. The older cheaper kits had the tindencey(spelling?) to crack cross member.
