351W - Which valve is which?
Old Apr 15, 2007 | 01:17 PM
HangGlider's Avatar
HangGlider
Question 351W - Which valve is which?
Ok - I know I had a diagram that told me which valve was exhaust and which was intake on my Edelbrock 60329 heads - but I can't find it. Is intake the closest to the radiator, or vice versa? Is it the same for the driver's side bank? Or is it switched 'cause the head is 'reversed' from side to side. I suppose it depends on the cam... ? [sigh] There's so much I don't know!!!!
Old Apr 15, 2007 | 02:31 PM
Piffery1's Avatar
Piffery1
Just look at the exhaust port on the number 1 cylinder (front, passenger side). If the exhaust port is very close to the front edge of the head then the exhaust valve is first in line. If the exhaust port is 2 or 2 1/2" back from the front edge of the head then the intake valve is first in line (verify by tracing where the intake manifold runner for that cylinder is located). If the sequence is IE,IE,IE,IE on one side then the sequence on the other side would be EI,EI,EI,EI.
Old Apr 15, 2007 | 02:34 PM
Drizzt's Avatar
Drizzt
if you have the valve covers off the exhaust valve will be inline with the exhaust port in the head.
Old Apr 15, 2007 | 03:18 PM
petes79f150's Avatar
petes79f150
Performer 60329-
Driver's side, front to back- EI EI EI Ei, pass. side fr. to back- IE IE IE IE.
Pete
Old Apr 15, 2007 | 05:45 PM
HangGlider's Avatar
HangGlider
Red face
Thanks for all the replies! It makes sense that the exhaust valve is closest to the exhaust port. Duh... Now I feel like a total idiot.
I appreciate the help though - thanks again.
HG
