1947 Front disc brake conversion
Old Apr 15, 2007 | 11:03 AM
47Lumbertruck's Avatar
47Lumbertruck
I am sure the answer to my question was posted here before but can't seem to locate it. I would appreciate anyone setting me straight on the following:
I am closing in on the final plan for modernizing the running gear of my 1947 1 ton, primarily so I can use modern wheels/tires. I would like to put disc brakes on the front using the stock suspension . If I remember correctly I will need to find 1948 F1 spindles which will fit the 1947. Then I can use one of the disc brake kits available to fit 1948 spindles. Do I need to consider if spindles/brakes are strong enough for the somewhat heavier truck? What are good sources for the spindles and brake kits? ( Since this is a saftey issue I am looking for quality first and price second.) Thanks very much in advance for input.
Old Apr 15, 2007 | 02:13 PM
46fordtruck's Avatar
46fordtruck
The 1/2 ton spindles are adequate for your truck. That is the same route I am going on my '47 1 ton, except that I will be using the spindles from a '46 1/2 that I have here.
You can find the kits at most street rod shops. I have never heard of any really being of bad quality. I used a kit from a local shop, uses GM calipers and Mopar rotors since I wanted the 5 on 4.5" bolt pattern. The only issue you might have an issue with is if you want to retain the 5 on 6.5" bolt pattern that the 1 ton uses. I have not seen a kit offering this bolt pattern
Old Apr 15, 2007 | 02:27 PM
RedSkin12B's Avatar
RedSkin12B
This site might have a some info for ya.
http://www.mpbrakes.com/index.cfm
Brad
Old Apr 17, 2007 | 04:25 AM
47Lumbertruck
Your reply suggests that spindles from 46,47,48,?, 1/2 ton would fit. Does anyone sell those new or NOS? Thanks for the help.
Old Apr 18, 2007 | 01:19 AM
46fordtruck
The spindles from the '42-'48 1/2 ton will fit. In fact, the 1 ton uses the same axle as the 1/2 ton. I thought I have head of reproductions of these being made, just not sure off hand who it is. You can always get a used set and have them magnafluxed to ensure they are good to use.
Old Apr 18, 2007 | 07:12 AM
47Lumbertruck
Thanks for that and also thanks to Redskin. That link looks like a good source for brakes and also a new 9" rear. Are there any advantages or disadvantges to going with 4 3/4 as opposed to 4 1/2" 5 bolt wheels. I am planning to use steel wheels that will take the Ford caps and trim rings.
Old Apr 19, 2007 | 12:32 AM
46fordtruck
Not advantage or disadvantage. I'm going with the smaller pattern based on the rear I am using (8") and it's current bolt pattern. I believe that 5 on 4 3/4 is a GM pattern, which won't match the bolt pattern from a Ford rear. If you are using a Ford rear then use either 5 on 4 1/2 or 5 on 5 on 5 1/2. The half ton Ford pickups used the bigger pattern, most cars used the smaller pattern. Of course, this is if you are concerned with having the same bolt pattern on all 4 wheels.
Old Apr 19, 2007 | 10:11 AM
46yblock's Avatar
46yblock
Speedway sells or use to sell pre 48 spindles. I put one of their Wilwood heavier duty kits on my 46. It includes 4 piston calipers. Rotors are 10 3/4 inch. Calipers and hubs aluminum. Very nice, effective, and easy installation.
Old Apr 19, 2007 | 10:32 AM
47Lumbertruck
Thank you. At the moment Speedway offers " 28 - 48 forged spindle" which are out of stock. Are they just for cars or will they fit trucks too?
Old Apr 19, 2007 | 10:39 AM
46yblock's Avatar
46yblock
My understanding is that the spindles fit trucks too. The kit I mentioned is billed for cars, but also fits 1/2 tons.
Old Apr 24, 2007 | 10:18 AM
47Lumbertruck
Thank you,
This may be an impractical idea but how different is the 1 ton spindle? Could a machine shop make it fit the 1/2ton hub?
Marklea
Jul 27, 2016 12:41 PM
Smoke123
Jul 7, 2016 04:15 PM
green1951truck
Jun 24, 2016 10:46 AM
air5dad49
Jun 5, 2009 12:29 PM
ToddSS
Sep 10, 2003 08:06 AM
