Trucks fixed!!!
Old Apr 15, 2007 | 10:37 AM
ballbandit's Avatar
ballbandit
Trucks fixed!!!
After alot of brain storming the truck is fixed. The truck is a99 that would run sometimes and sometimes not. The truck might start the it may not. After checking alot of different things i finally checked the icp pressure and when i seen it was only 130 psi while cranking I decided to change the ipr valve first and what do you know the pressure went up and the truck is still running.
Old Apr 15, 2007 | 10:39 AM
Uzumati's Avatar
Uzumati
The IPR will do that, good to hear ya got her fixed.
Old Apr 15, 2007 | 12:58 PM
vettdvr's Avatar
vettdvr
So what's a IPR and what is it's full time job? Jim
Old Apr 15, 2007 | 03:56 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Injection pressure regulator- It regulates, well the injection pressure. It is located on the bottom side of the High Pressure Oil Pump, and it dumps pressure back into the front cover, down to the crankcase to manage injection oil pressure.
EricdeToad
Feb 24, 2015 09:27 PM
Polkster
Sep 6, 2014 09:39 PM
6.9lXLTf250
13
Jul 12, 2010 12:28 AM
glu252
Sep 14, 2004 06:17 PM
Greaser
Aug 18, 2004 09:23 PM
