84 f150 inline six thermostat problems
Old Sep 13, 2004 | 03:53 PM
glu252's Avatar
glu252
my truck runs good, but sometimes it will over heat on very hot days . could it be a stuck thermostat? it will do it only after i turn the truck off, my buddy told me to check the pressure it might be the problem, the older trucks call for a different pressure ? can you help me out
Old Sep 13, 2004 | 05:33 PM
4x4fordtrkn's Avatar
4x4fordtrkn
see if this helps
https://www.ford-trucks.com/forums/s...d.php?t=269992
Old Sep 14, 2004 | 06:17 PM
Tranzmaan's Avatar
Tranzmaan
overheating
If everythings is OK until you turn off the motor and then the radiator boils over, you may have a partially clogged radiator. Do you have a temp gauge or an temp lite? If its a gauge, where is the needle at while the engine is running?
jerryparks
13
May 26, 2015 06:47 PM
blue briar
Oct 1, 2014 07:57 PM
rascal1
Aug 22, 2014 05:56 PM
Nitro 54
1997 - 2003 F150
Apr 25, 2014 09:27 PM
Steve
Apr 4, 2006 11:46 PM
