429 misses under load
Old Apr 15, 2007 | 09:04 AM
fordtruckn's Avatar
fordtruckn
OK, here is my problem and I hope you can help. I have a 429 in a 69 ford F250. It is a new rebuild with an MSD ignition, wires and coil. It ran great when I first fired and I drove it for around 350 miles. It now has a severe miss. Seams to idle OK, but when but under a load, will hardly run. It backfires and misses. I changed the coil (3 times) and it seemed to clear up for a brief time, but then starts up again. I swapped carb, no change. I took the distributor, coil and wires out, but them in a box and sent them back to MSD to have them checked and they came back reporting there was no problems and everything checked out OK. I have moved the ground on the distributor, rewired the whole truck, changed the ignition switch and pulled out what little hair I did have. Any Ideas? Please help!!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Apr 16, 2007 | 10:34 PM
LxMan1's Avatar
LxMan1
What do the spark plugs look like?
Old Apr 17, 2007 | 08:51 AM
fordtruckn's Avatar
fordtruckn
They look whitish to light brown.
Old Apr 17, 2007 | 11:48 PM
LxMan1's Avatar
LxMan1
That sounds about normal. I wonder if you have a bad primary wire going to the ignition that is dropping voltage to the coil??
Kart18
437
Mar 14, 2018 05:20 PM
DonKid
Nov 14, 2012 07:51 AM
DonKid
Nov 9, 2012 08:30 PM
SBrown732
Apr 13, 2009 08:47 PM
axbrya
Dec 21, 2007 11:18 PM
