Will I be able to run 315/75R16 on 16*10 rims with only minor rubbing on level ground with the DR mini-pack springs? I would rather get the 3 inch hanger kit, but I dont think it will fit with my western plow mount. My truck is a 2000 F.250 S/C S/B 4x4
you shouldn't have any problem, but you might want to run a 16x8... looks better, IMHO, not to mention the tire/wheel won't stick out another 2"... you shouldn't rub, with the right backspacing...
Recently installed 315s. The only rub was at full turn right. The tire rubbed the leaf spring. For good measure I gave myself another 1 inch of clearance to the fender liner by modifying. See gallery.
