1978 - 1996 Big Bronco
Fuse #4 keeps burning out
Old Dec 14, 2001 | 09:45 AM
duke96eb's Avatar
duke96eb
Any thoughts or similar experiences would be appreciated. I just picked up another Bronco (91XLT 5.0 5spd) and every 30-60 mins of driving at various speeds and road conditions the dash lights and tail lights go out. I pop a new fuse in and it's fine again. My mechanic checked all the connections and suggested replacing the headlight switch due to its multi-functions sometimes causing an overload. Is this a typical Ford quirk? Broncos do have their odd habits but this is a new one on me.
Old Dec 14, 2001 | 11:29 AM
broncoman's Avatar
broncoman
You prob have some wire rubbing against a metal part and shorting out. Had the same prob with a wire rubbing against the frame and everntually blew my fuse controlling my transmission, speedo. I lucky looked at some wire comming from trans and seen the rubbing wire. get out the flashlight and start looking for bare wires.
Old Dec 15, 2001 | 11:50 AM
93EddieB's Avatar
93EddieB
this happened to me too. it turned out that one of the wires for the license plate lights had come out and was grounding on the bumper. i fixed it and it has never happened again..hope this helps.......turn on your headlights and check all exterior lighting.
Old Dec 15, 2001 | 01:14 PM
duke96eb's Avatar
duke96eb
I'll check that right away. You'll notice I had another possible solution but yours sounds too good to be true! It's worth a shot if it can save some time and exasperation!!
Old Dec 15, 2001 | 10:56 PM
honney's Avatar
honney
