2005 conv. complete
Old Apr 15, 2007 | 01:07 PM
John311t's Avatar
John311t
The tow hooks where taken off by the previous owner when he installed the body lift. I'm trying to find a cheap OEM ones to see if they will fit or not, because normally when a body lift is installed, you cant use the tow hooks, but i believe on my truck they will, it looks as if there is enough room.
The whole air filter thing, when i first had the 6637 on, it was pulling on the boot at the turbo, so i tried and tried and tried to get it not to. After no luck with that i got a piece of 4"45*pipe and tried that but the same thing was happening, it was pulling the boot at the turbo down i did not want it to fall off, or rip. So after trying a few things i finally got it to not pull on the boot, what holding the filter up is the radiator hose clamp, and the battery. It sitting right on top of the 2. The body lift really messed with installing the filter.
All in all from start to finish, this whole project took about 6 hours, and 4 of them was cutting the grille to fit and look good. So install on the light was about 2 hours since I forgot to look at what to cut in the header panel, so the right side took about 1.5, and the left side took about a half hour.
Old Apr 15, 2007 | 01:20 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
That looks really sharp.
Great job!
Old Apr 15, 2007 | 04:33 PM
John311t's Avatar
John311t
Thanks guys for the compliments. Now that the front end is done, time to start the stacks project.
Old Apr 15, 2007 | 04:44 PM
crack's Avatar
crack
that looks deadly, I wanna do that mod SO bad.
Old Apr 15, 2007 | 05:30 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Ha i noticed the guy taking a leak and the filter as well as the absence of stacks when i first viewed them, but i wanted to get right to the point with the stacks question
Old Apr 16, 2007 | 12:11 AM
empiretc's Avatar
empiretc
Originally Posted by John311t
Im going to get the mirrors eventually, but i first want to make so they can be at least power, since my truck doesnt have power mirrors, but it has power windows and locks.
John, its not too hard to do. I was in the same boat. Power windows and locks, but not power mirrors. It was a half day affair, but not hard at all. I will try and find the thread where I posted the full break down of how I did the install.
I got the switch from the stealer for $20.
Old Apr 16, 2007 | 02:28 AM
ryaneverk2's Avatar
ryaneverk2
How did you go about preparing and cutting the grill? Did you run into any problems with the paint or whatever the coating is peeling?
Old Apr 16, 2007 | 06:44 PM
John311t's Avatar
John311t
What I did to prep the grille was to measure about an inch and then i taped it off and scared it with a razor blade to prevent the chrome from chipping. Then i used a die grinder with a cut off wheel to cut the grille. I cut everything behind it as well. Then i test fit it, and used a file to take off what was necessary after that.
Old Apr 17, 2007 | 12:26 AM
'99 STROKE's Avatar
'99 STROKE
I think anyone thinking about mods. has this one in the making somewhere.
Edit: Nice look. You can buy the whole package ready to go on e-bay. (bolt-on)
Old Apr 17, 2007 | 12:41 AM
empiretc's Avatar
empiretc
This mod was the first I did when I bought my truck back in 05 (mirrors, grille, badges)- everything except the headlights. They were still way too expensive so I got the projector style instead.
well, i am selling the projector headlights w/ corners along with the summit racing wiring harness upgrade and 2 sets of silverstar bulbs now.
if anyone is interested, PM me . They are gonna go cheap.
Old Apr 17, 2007 | 12:55 AM
TNT in Round Rock's Avatar
TNT in Round Rock
looks really good !
Old Apr 17, 2007 | 12:37 PM
John311t's Avatar
John311t
Now to make it so the highs and lows can stay on at the same time. You guys say something about a diode? Since i got the upgraded harness can i just put that diode somewhere or what?
Old Apr 17, 2007 | 01:51 PM
  #28
empiretc's Avatar
empiretc
You use the 9007 plug that didnt plug into the harness.
http://www.northtexaspowerstrokes.co...pgradeharness/
Old Apr 17, 2007 | 02:41 PM
  #29
wcklew's Avatar
wcklew
Empiretc, you got mail.
Old Apr 17, 2007 | 03:48 PM
  #30
John311t's Avatar
John311t
Thanks empiretc
Will be doing this after i fix the truck now, any time i do something to the truck something else misses up.
