Overheating
Old Apr 14, 2007 | 04:17 PM
gregj999's Avatar
gregj999
Overheating
I have an 89 Ford F150. I just replaced the factoy radiator, which was clogged with rust, and my truck still overheats. I dont have any coolant leaks. Could all of that rust build-up cause the water pump to fail, even though the pump is relatively new? If not the water pump, is the problem caused by a sensor or switch? This is starting to become expensive to troubleshoot.
Thanks, Greg...
Old Apr 14, 2007 | 06:44 PM
t4kne's Avatar
t4kne
Remove the thermostat. reconnect the hose. Remove radiator cap and run engine. Look inside, if you see fluid circulating in the radiator, buy a new thermostat. If you see no circulation, looks like it's the water pump.
Old Apr 15, 2007 | 03:28 AM
Chuckde's Avatar
Chuckde
Overheating
Could it be air trapped in the system? Does it really noticeably overheat or is the gauge registering higher than "normal", indicating a hot spot due to trapped air?
Chuckde
Old Apr 15, 2007 | 06:50 AM
dbellis's Avatar
dbellis
i agree sounds like the thermostat id try that and could be the cluch fan see how free it moves
Old Apr 15, 2007 | 09:32 AM
88 f150's Avatar
88 f150
I agree on the thermostat. Could be corroded shut or nearly shut. Check also your coolant sensor. Most shops will have a infrared temp gauge they can use to find hot spots.
