Sponsored by: Innova
sirius mounting
Old Apr 14, 2007 | 11:34 AM
autx790's Avatar
autx790
sirius mounting
I got the sirius sportster4 unit, but unfortunately the sirius mounting devices that come with the car kit are crap. I'm looking to make something myself, but was wondering how other people have mounted their plug and play receivers. Any pics would be appreciated. This is going in a 95 Bronco.
Old Apr 14, 2007 | 05:40 PM
ReAX's Avatar
ReAX
I haven't done that, but I have done several Edge attitudes. Velco and closed cell foam are your friends. If you need to space the device out of a hole, bend up a peice of steel and screw it down. The foam will close up any gaps and the velco allows solid mounting and removal.
Old Apr 14, 2007 | 06:09 PM
autx790's Avatar
autx790
well i've got something i'm working on now, however, i seemed to have lost the screws that go into the docking station, so i'm screwed till i find them. I'll try to post a picture when I get done.
Old Apr 15, 2007 | 09:22 AM
Razor404's Avatar
Razor404
You could try this Bronco (full-size) 1992-1996 (FO-74-92) Description
but it looks like it's going to block your heater controls. I bought the mount for my truck and love it, although it dosen't block anything.
Old Apr 15, 2007 | 09:25 AM
autx790's Avatar
autx790
yeah, I had seen that one, but didn't like that it blocked the A/C control. So i'm trying to make something similar but that will bend the other way. And then at least I'll have cold air blowing on it to try and keep it cool.
Old Apr 15, 2007 | 10:44 AM
BigOle'Ford's Avatar
BigOle'Ford
I know back at the install bay we use Sheets of black Plastic and use a heat gun to bend it anyway we please. Makes a nice, finished looking bracket for you to mount where you please. Theres also a company call Bracketron we use, they often have very nice mounts simliar to the one you saw but maybe have different mounting locations?
Nick
Old Apr 15, 2007 | 11:49 AM
autx790's Avatar
autx790
Man, I didn't even think of trying to mold plastic with a heat gun. I'm using a piece of sheet metal that I spray painted flat black. Not the easiest to work with. Thanks for the info on bracketron. I looked them up but I didn't see any for a bronco and the F-150s only went back to 1997.
Old Apr 15, 2007 | 01:04 PM
autx790's Avatar
autx790
I don't know how to post in here, but i put a pic in my gallery of what i did.
Old Apr 15, 2007 | 01:37 PM
Razor404's Avatar
Razor404
Nice job. Looks great where you put it.
Old Apr 16, 2007 | 10:03 PM
BigOle'Ford
I personally wouldnt have put it in front of that vent, but you definately did a very clean install, do you have any pics of the bracketry you fabbed up? Good looking install bro.
Nick
Old Apr 17, 2007 | 07:42 AM
autx790's Avatar
autx790
Thanks, I'll try and get some pics some time this week or this weekend. It's nothing fancy, but it doesn't show that much and does the job. I would have preferred to have it mounted up higher where i wouldn't have to look down much to see it, but this was the place I could put it close to me and without drilling any holes. It doesn't cover the air vent completely so i can still adjust it and i read that these units run hot so it will at least keep it cool in the summer, not that i even use the A/C that much anyway.
Old Apr 17, 2007 | 09:31 AM
ckal704's Avatar
ckal704
Don't have any pics, but I mounted mine where the headliner meets the windshield. The front edge of the docking station slid under the plastic trim and then two large diameter (#14, I believe), but relatively short, sheet metal screws were used to attach the other end of the docking station base to the fiberboard headliner.
Hasn't budged in over 2 years.
So the unit sits up and above the rear view mirror.
Dang- I really need to get a digital camera.
Old Apr 17, 2007 | 09:37 AM
autx790's Avatar
autx790
Yeah you do, i'd like to see what you did there.
ggadwa
Nov 17, 2012 03:52 PM
Thephys
2009 - 2014 F150
34
Apr 6, 2010 06:58 AM
ksutjh
Jul 11, 2007 03:44 PM
XylemXorro
Jun 2, 2007 06:26 PM
schmity
Jan 16, 2007 10:40 AM
