interchangable IP
Old Apr 13, 2007 | 08:13 PM
f100guy's Avatar
f100guy
interchangable IP
will all IP's work on all 6.9 and 7.3's. i have access to test my 85 6.9 IP on a 94 7.3 idi. can i do it.
Old Apr 14, 2007 | 07:44 AM
f100guy's Avatar
f100guy
ttt please help
Old Apr 14, 2007 | 09:37 AM
PLC7.3's Avatar
PLC7.3
You can install it yes........but as to whether it will operate that engine correctly very doubtful. The old 6.9 IP and the (performance and emmisions) 7.3 (94) IP are different in many respects. For starters the 94 injectors pop off at a higher PSI 1950 and the 6.9 injectors at 1825 so there would be a timing issue there for starters.
Old Apr 14, 2007 | 08:38 PM
f100guy's Avatar
f100guy
well i heard it didn't work so i did not do it.
Old Apr 15, 2007 | 01:46 AM
Dave Sponaugle's Avatar
Dave Sponaugle
It would probably be better to take the IP to an injection servive and have it bench tested.
That would be far easier than swapping the IP to a different engine and then swapping it back.
The 85 IP would start the 94 engine, but since the injectors are not matched to the IP it would not run right. So your test would not prove anything.
Swap the IP and injectors and you would be closer to being able to tell something, but that is a lot of work.
After all that you will be replacing the copper washers and return cap O rings on two motors as well as setting the timing.
If it runs badly you still need to have it bench tested and/or replaced, so why not just do that first and save a lot of work and expense.
Old Apr 15, 2007 | 08:41 AM
f100guy's Avatar
f100guy
the only injection place i know of said they don't test them, only rebuild them. i already tried that.
Old Apr 15, 2007 | 08:56 AM
PLC7.3's Avatar
PLC7.3
That is correct....... most rebuilders will not put someone's used IP/junk on thier senative and expensive machines just to prove a point.
Old Apr 15, 2007 | 11:51 AM
f100guy's Avatar
f100guy
yeah well then they won't get money from me. for all i know, the IP is good and i don't want to fix rebuild something that is not broken.
Old Apr 15, 2007 | 01:17 PM
Dave Sponaugle
How many miles are on it?
If the answer is over 100,000 miles then it is due if you want the best out of it.
Yes they still run after 100,000 miles, but the power and MPG just drop off slowly.
Injectors are in the same category.
Old Apr 15, 2007 | 01:22 PM
f100guy's Avatar
f100guy
not sure, the IP has been rebuilt and it looks pretty clean. i am begining to think that the problem is air intrusion instead of IP. if you go to my other threads you may see what i am talking about better.
Fireman_dave
Oct 6, 2011 12:02 PM
Rocketattack
Sep 13, 2011 12:36 PM
ravedaber
Feb 7, 2011 01:16 AM
vintage super duty
Mar 24, 2007 11:40 PM
barneyfife410
Oct 30, 2006 04:19 PM
