Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Morris
Old Apr 13, 2007 | 07:58 PM
Snowking's Avatar
Snowking
Morris
If you can try to avoid running the 53 1 ton, the more dry the piston s are for tommorrow the more accurate my valve test will be.
Old Apr 13, 2007 | 09:47 PM
Fomoko1's Avatar
Fomoko1
Too late Chris and I had it running a little while ago.
All we need is a ruff idea of what the compression is, seems it`s running ok but hard to tell with all the exhaust noise....
It`s been sitting for years and seems to run better the more I run it.
We got the front end off today so it`s easier to do the test, still runable with the rad hooked up.
Old Apr 13, 2007 | 10:34 PM
Snowking's Avatar
Snowking
Thought I saw the box hanging out the back of your shop while I drove past from work. Oh well A flathead always needs a valve job....
Old Apr 13, 2007 | 10:48 PM
effie_man's Avatar
effie_man
it was only running for less than 5 minutes just to move it around twice
Old Apr 13, 2007 | 10:52 PM
Fomoko1's Avatar
Fomoko1
You should have stopped in for a minute or two.
Looks quite different without any front fenders, hood and grille.
mtflat
66
Sep 24, 2011 06:44 PM
havi
Dec 28, 2008 04:51 PM
preppypyro
29
Apr 6, 2007 10:31 PM
