power
Old Apr 13, 2007 | 05:59 AM
dieselmec's Avatar
dieselmec
Question power
can someone help me figure out what is wrong with my 1991 f250 7.3 non psd
towing a 6000 lb 5th wheel with od off even the smallest hill i have to push the pedal all the way to the floor and still cannot go but 45 to 50 mph the truck has 97000 miles on it?
Old Apr 13, 2007 | 06:28 AM
fonefiddy's Avatar
fonefiddy
@ 97k Miles, the fuel system is prolly getting tired.
Do you use a fuel additive?
Old Apr 13, 2007 | 06:30 AM
dieselmec's Avatar
dieselmec
yes on every fill up
Old Apr 13, 2007 | 06:34 AM
dieselmec's Avatar
dieselmec
do i need a new ip pump and injectors?
Old Apr 13, 2007 | 07:11 AM
fonefiddy's Avatar
fonefiddy
It's very possible. Are they OE?
How's she start in the AM?
Old Apr 13, 2007 | 08:01 AM
dieselmec's Avatar
dieselmec
yes they are starts right up runs great does not seem to pull harder enough
Old Apr 13, 2007 | 02:42 PM
crossbones2's Avatar
crossbones2
How long has it been:
new fuel filter;
fuel pressure tested at filter;
injectors cleaned and tested;
timing set;
Old Apr 13, 2007 | 04:03 PM
KJLYPW's Avatar
KJLYPW
Do you have any intake mods, soup bowl removed, bigger snorkel, and most important, how big is your exhaust system. The stock 2 1/2 on the 7.3 are very restrictive, must have been designed for sound, cause it sure wasn't for power. Exhaust on N/A should be at least 3" and if you need to change it anyway, go for 4".
With the weight your talking, the old N/A at 45-50 is doing OK if everything is still stock.
Old Apr 13, 2007 | 05:12 PM
whatsparkplug's Avatar
whatsparkplug
How fast are you able to go on level highway pulling that weight? When I first got my truck with 122,000 miles I could only get about 55mph tops on level road pedal to the floor. Changed the filters and better, changed the ip after that and made even more improvement. Haven't pulled my camper yet(about 6500lbs loaded) since changing injectors but this has made a BIG difference in power empty. I'm still learning about these older diesels but with the help of these guys on this board you can do just about all these things yourself. I personally value the opinions I get on here much more than some Jack-*** shop that tells me to just leave it and we''ll check it out and give you a bill. I've heard many people say these trucks are total slugs and gutless, and I thought that same thing soon after I bought mine. My dually is all stock still but I can tell you that now it's far from a slug and has very good pep.(now to get this damn tranny to shift right!) Sorry for the long post but that's my 2 cents.
Old Apr 13, 2007 | 05:48 PM
Dave Sponaugle's Avatar
Dave Sponaugle
How much frontal area does the fiver have?
You are not just pulling 6000 pounds, you are pulling a sail also.
70 square feet of frontal area takes 78 HP to maintain 55 MPH on level road.
Old Apr 13, 2007 | 06:26 PM
datamover's Avatar
datamover
Dave, how much HP to pull that "sail" at 70?
Bob
Old Apr 13, 2007 | 06:57 PM
Dave Sponaugle
I do not have those numbers, but I can tell you the increase is not linear it is more like exponential.
90 square feet at 55 is 99 HP.
I have a rather large frontal area.
I am working a little over 120 miles from home right now.
If I drive 70 to 75 MPH my MPG is 10
If I drive 60 to 65 MPH my MPG is 13.5
Fuel is 3.11 a gallon here now.
Time for an overdrive.
Old Apr 13, 2007 | 09:11 PM
tbone91's Avatar
tbone91
Is you air cleaner dirty? If the engine can't breath, it won't make much power.
