oil leak
Old Apr 12, 2007 | 09:42 PM
pstroker's Avatar
pstroker
oil leak
im sure this has been addressed many many times in the past but ill ask anyway,my 7.3 has developed a small oil leak from the back of the motor,it leaves a spot about the size of a quarter consistantly on my driveway,is this an easy fix ive heard about o rings leaking any help is appreciated
Old Apr 12, 2007 | 10:27 PM
SolidGround's Avatar
SolidGround
Which 'o-ring?'
I'll take a stab, possibly HPOP o-rings or pedistal o-ring...
HPOP oil line o-rings...easy.
Pedistal...a little more work.
Old Apr 13, 2007 | 08:36 PM
pstroker's Avatar
pstroker
i am gonna steam clean the back of the block i then run a few miles and i guess with an inspection mirror see where its coming from i assume these o rings as are dealer available hope it is obvious where its coming from.......Thanks Marc
Old Apr 13, 2007 | 09:30 PM
white Buffalo's Avatar
white Buffalo
Yeah, clean the engine off real well with some simple green and see where the leak is originating from. Is there any oil in the engine valley? Any leak on top of the engine ends up draining down the weep hole past the bell housing area/between the tranny & engine.
Like stated above some common culprits are:
HPOP rings
pedestal O-rings
oil build up from CCV leaking out the boots
Old Apr 13, 2007 | 09:36 PM
pstroker's Avatar
pstroker
Thanks a lot i will be in touch
