Rear C- Notch kits?
Old Apr 12, 2007 | 06:44 PM
68murc's Avatar
68murc
Question Rear C- Notch kits?
Does anyone know of any simple bolt-in, or weld-in C-notch kits for the rear frames on these trucks? Thanks in advance from the gettin' warmer North.
Old Apr 12, 2007 | 10:46 PM
Dave Severson's Avatar
Dave Severson
A few companies make them, can't give you a name off the top of my head. What I usually uses is a piece of 4" or 4 1'2" thin wall (11 ga. or so) cut in half lengthwise. Trace the outline of the tubing over the frame rail where it is centered over the axle tube. Cut out that section of frame, weld in the tubing. Quick, easy, cheap, and works good.
