73 4x4 towers
Old Apr 12, 2007 | 10:37 AM
mtflat's Avatar
mtflat
73 4x4 towers
My son-in-law is swapping a 300 into his 73 4x4 half-ton and we're shopping for towers. Need to know what we're looking for exactly.
Anybody know if the 4x4 and 2wd towers would be different?
Anybody happen to have a set laying around that you want to get rid of?
In case you're curious, the truck vin shows it had a 360 orig, but a po swapped in a 302. We've pulled out the 302 towers after grinding gobs of weld off - went by the theory if you can't weld good, weld alot. Anyway the frame is clean and ready for 300 towers.
Thanks, Tim
Old Apr 12, 2007 | 11:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Are refering to engine perches aka engine mount brackets when you say towers?
Old Apr 12, 2007 | 11:12 AM
mtflat's Avatar
mtflat
Yes, Bill. The metal bolt-on perch that the insulator/mount sits on. Thanks.
Old Apr 12, 2007 | 11:32 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
4x4 and 2wd have different towers/perches.
Old Apr 12, 2007 | 11:34 AM
NumberDummy
By the parts catalogs, you don't have too many choices, but someone here may know that something else can be adapted, or that someone makes a kit to do what you are planning.
D6TZ-6028-A .. R/Side Perch
D6TZ-6029-A .. L/Side Perch
The above numbers fit: 1973/76 F100/F250 4X4's, and 1977 F100/250 4X4's before serial number Y20,001. The left side perch only also fits 1979 F150 4X4's. The 2WD perches are different.
I'm afraid that's it. The earlier 1965/72 4X4 240/300's show different parts numbers for the perches. I also looked at every part number for every engine perch Ford offered from 1965 thru 1979. No other matches could be found.
