Abs Lite
Old Apr 12, 2007 | 09:36 AM
WILDMAN_Stroker*7.3's Avatar
WILDMAN_Stroker*7.3
Abs Lite
My ABS lite comes on sometimes and sometimes not, checked all brake pads they all look good rotors are in very good shape, fluid level is full. Tryed running a code on it, but I don't know if my code reader will give the codes for the ABS. Any help or suggestion!!!
MIKE
Old Apr 12, 2007 | 09:51 AM
wfmcbride's Avatar
wfmcbride
Your code reader probably doesn't read Ford codes, when my ABS light came on the problem was the VSS sensor located on top of the differential, I picked one up at NAPA for about $12.
Old Apr 12, 2007 | 01:36 PM
clintbonnie's Avatar
clintbonnie
Napa's P/N is 530780... $10.47 napaonline.com .. note: some stores charge more if you walk in..Easy to change.. remove bolt and pull straight out..
Old Apr 12, 2007 | 02:08 PM
Pocket's Avatar
Pocket
It could also indicate bad wheel bearings. My ABS light came on and Autoenginuity picked up the code for the driver's side front sensor fault. Come to find out the wheel bearings were trashed and took out the sensor with it.
Lift up the front of your trucks and grab each tire and try to wiggle it around. There should be no play and it should spin freely without any strange noises.
Old Apr 20, 2007 | 07:51 AM
WILDMAN_Stroker*7.3
Smile found problem
ABS light was coming on intermittingly, found problem with a wire near the front dirvers side wheel was grounding itself.
