6 Speed???
Old Apr 12, 2007 | 07:52 AM
Ford_dad's Avatar
Ford_dad
Question 6 Speed???
Hey, got a question. What is the best fluid for our six speed trans, i need to change but am not sure what to use... '99.5, 6 speed, 2wd.
Thanks, Joe
Old Apr 12, 2007 | 09:07 AM
fcfirefighter05's Avatar
fcfirefighter05
I used mobil 1 syn...I think you'll like it and find that guys recommend it. Shifts easier once I switched
Old Apr 12, 2007 | 05:36 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I use Royal Purple ATF.
Old Apr 12, 2007 | 05:59 PM
pullinair's Avatar
pullinair
Royal purple "Synchromax" Manual trans fluid -here. Synscromax- specially formulated for manual transmissions requiring ATF. I appreciate it the most in the cold months during winter. No- missed/hard shifts this past winter with this stuff.
Old Apr 12, 2007 | 09:38 PM
cookie88's Avatar
cookie88
FTE Emeritus
I was going to go with the synchromax, but RP's website used to say that manuals that require mercon ATF should use RP's Max ATF instead of synchromax. I will admit that I haven't checked their site in the last year or so.
Old Apr 15, 2007 | 09:32 PM
Ford_dad's Avatar
Ford_dad
Hey guys thanks for the help, i just did a new clutch and you always loose some then... I figured it might be time to change it, about how much does it take???
Thanks Joe
Old Apr 16, 2007 | 10:24 AM
crack's Avatar
crack
what is a common interval to change the trans fluid?
Old Apr 16, 2007 | 12:24 PM
Fat Diesel's Avatar
Fat Diesel
I change mine just about every 50,000 miles. It should take about 5.8 quarts.
Old Apr 17, 2007 | 01:34 AM
crack's Avatar
crack
alright...I should probably give minea change. ha
