Question about DP-Tuner no-start program.
Old Apr 12, 2007 | 05:39 AM
maevans's Avatar
maevans
I have a question about what is the right way to use the No-start with the F-5 switch.
After done driving, I been turn the truck off, then turn the key back to the on position and then set the tuner to the No-start program.
I tried leaving the truck running then set the tuner to the No-start program and in worked. I prefer to use this method .
So after reading and re-reading DP instructions, it says -( with the key in the on position ) set the tuner to the No-start program, It doesn't say anything about setting it with the truck already running.
So what is the correct way ? What way have all of you been using ? Thanks...
Old Apr 12, 2007 | 07:46 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Position 0 operation-
*Accessing position 0-
Press both buttons while key is on. The chip will not change to position 0 while the key is on. The display will blink on position 0 and it does not go to that position until the key is turned off. The display will not light when the key is in position 0.
*Exiting position 0-
Turn the ignition to on. Press and hold both buttons for 3 seconds to exit. The switch will return to position 1.
None of this is while the truck is running. Only with the ignition in the "on" position.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Apr 12, 2007 | 10:58 AM
Strictly Diesel's Avatar
Strictly Diesel
FTE Sponsor
Let me clarify this a bit. I see that Diane was replying at 5:46am...maybe without her morning coffee?
YES, you can switch to Position 0 while the truck is running. On my 02 that's exactly what I do, before I turn the truck off I hit both buttons to put it into 0. Once you shut off the key it's locked in 0.
To exit position 0, press and hold the left button for 3 seconds (no need to hold both). This will obviously be done with the engine off because the truck won't start.
HTH
Old Apr 13, 2007 | 05:39 AM
maevans's Avatar
maevans
Thanks for explaining the correct procedure to use the 0-positin.
Tugly
Dec 12, 2018 09:31 AM
Pele
Modular V10 (6.8l)
Dec 13, 2015 10:28 AM
rob_jones
Aug 10, 2015 10:47 AM
HappySailor
15
Apr 16, 2015 04:10 AM
Norm Carter
1978 - 1996 Big Bronco
Sep 10, 2003 09:54 PM
