Bronco II Ford Bronco II
B2 Rear Wheel Lockup while Downshifting
Old Apr 11, 2007 | 08:24 PM
ojz2001's Avatar
ojz2001
Has anyone ever experienced the rear wheels of your B2 locking while downshifting your manual transmission from highway speed? This is a 1987 B2 XLT. Transmission has been gone through. Cannot isolate where the trouble might be.
Old Apr 12, 2007 | 05:29 AM
kernel-panic's Avatar
kernel-panic
Are you downshifting at too high of a rate of speed for the gear you are downshifting into???????? If you have the owner's manual, it should tell you in there what the maximum speeds are for downshifting, and I can't remember if it's on the driver's side visor as well. I'm going to guesstimate here, but I believe the numbers are something like this: 4th - 40/45, 3rd 30/35, 2nd 20/25 1st 5/10. These could be a tad on the high side, but close to what the numbers are in the owner's manual (and generally speaking close to the numbers for ANY 5-speed transmission equipped car or truck). If you actually get the transmission to shift into a lower gear at too high of a rate of speed and release the clutch, the rear wheels will lock up or "chirp". This is also bad for the driveshaft, rear axle / differential, as well as the clutch and transmission / t-case, especially the tranny because you can damage synchros and gears.
Old Apr 12, 2007 | 08:11 AM
powrstrkr's Avatar
powrstrkr
B2 trannies are not that strong. Ask me how I know! If you're downshifting hard enough to lock up your rear end you are abusing your driveline. A B2 is not a sports car and shouldn't be driven like one. Use your brakes and save your clutch, tranny, t-case, ujoints, etc. It's a lot cheaper to replace brake pads/shoes than driveline parts.
Old Apr 12, 2007 | 09:38 AM
kernel-panic
Exactly where I was going, powr... I've seen what happens when you blow gears/synchros/bearings in a manual transmission... it's UGLY. Not to mention, if his rig has that crappy GKN junk of a rear driveshaft... those things don't handle a whole lot, either. Okay, just for fun, I'll ask... How do you know, powr?
Old Apr 12, 2007 | 10:34 AM
powrstrkr's Avatar
powrstrkr
Haha!! I'm on my 3rd TK 5spd with a total of 6 tranny removals for rebuilds or replacements. But the last place to rebuild it did a great job and it's held up pretty well for 7 or 8 years and prolly 100K mi. I've had the truck since birth and never really beat on it, although it's now mostly a rock crawler and not a DD.
Old Apr 12, 2007 | 01:21 PM
ojz2001's Avatar
ojz2001
this seems to be a complete mechanical lockup and not an engine compression rear wheel chirp. The engine actually stops (engine lights come on) until i quick depress the clutch and the engine continues. Once the clutch is release everything is fine. I can continue. in some cases the engine has comepletely stopped. i was thinking something more in transfer case. but i am at a total loss.
Old Apr 12, 2007 | 03:12 PM
powrstrkr's Avatar
powrstrkr
Sounds to me like you have good compression. Are you trying to blow your engine or toast your driveline? If I were you I would stop downshifting like that. Seems like it runs fine so stop downshifting and don't worry about it. Why do you need to be downshifting? You are trying to drive it in a way for which it was not designed. You're only asking for major trouble if you continue downshifting. One thing that comes to mind - you're not shifting your t-case into low range are you? We're talking explosion if that's what you're doing.
Old Apr 12, 2007 | 07:45 PM
ojz2001's Avatar
ojz2001
When i downshift, it's not that I'm using the engine compression to slow myself down, I'm downshifting so that i can continue moving at a lower speed. Like when leaving the highway and and i need to make a turn at the end of an offramp where i have not completely stopped. it is difficult to continue a turn at 15 mph in 5th gear. I'm just trying to use the correct gear for the speed that I'm moving at.
Old Apr 13, 2007 | 12:08 AM
kernel-panic
Uh, you're not giving it enough gas to keep the engine running and/or letting off the clutch too quickly or like we've already said... downshifting at the WRONG speed into the WRONG gear? Sounds like you need a little more practice driving a manual transmission....
EDIT: UH, you're not shifting all the way down into 1st gear are you??? You'll eat the transmission, or rather, it will grenade if you keep doing that. 2nd is plenty far down for 15 mph.
Old Apr 13, 2007 | 12:54 PM
ojz2001's Avatar
ojz2001
KP - thank you for taking the time to respond.
Old Apr 13, 2007 | 05:08 PM
jdhv002's Avatar
jdhv002
sounds like may have two shift forks moveing at the same time, trying to go into two different gears at the same time, that will lock it up. other than that i don't have a clue
Old Apr 13, 2007 | 06:09 PM
ojz2001's Avatar
ojz2001
jdhv - THANK YOU!!!!! I just found a trans shop that seemed to have experience with B2s, his comment was similar, a bent shift fork. Not fully disengaging the previous gear causing two gears to mesh and bind due to the ratios.
I've built quite a few offroaders with standard transmissions over the years, this is my first B2 and I knew it had nothing to do with the way i was driving it. Thanks again!
Old Apr 13, 2007 | 08:17 PM
kernel-panic
Bent forks are only caused by one thing: The person driving the truck.
Old Apr 14, 2007 | 09:30 AM
kernel-panic
Also, another notable problem with pre-M5OD transmissions is the shifter. My '86 Ranger would jump in and out of gear and sometimes I couldn't even shift, and it did the lock-up thing once. Found out the shifter had lost some parts, so... ended up eventually replacing it, but drove it for the longest time with an 'engineered fix'.
nicksorenson
24
Jan 8, 2020 12:22 PM
JoeLaMa
Nov 21, 2014 08:04 PM
2bizze
Jun 7, 2013 08:14 PM
Bolder1235
Jul 4, 2011 11:06 AM
Flightsimmer
Oct 25, 2009 07:31 PM
