Carb problems
Old Apr 11, 2007 | 03:56 PM
jasonr2210's Avatar
jasonr2210
Carb problems
I have a 75 f100 4x4 that i just attempted to rebuild the carb on cause the enrichment valve was shot. got it running but now I am getting a popping noise thru the carb. doesn't happen at idle or when revving the motor , only when uinder a load, mainly at lower rpm lvls when trying to accellerate quick. I am mechanically inclined but know crap about carbs. First mistake was probazbly trying to rebuild it mysefl but im a cheap *******. Has a motorcraft 2150 2bbl carb. Any help would be greatly appreciated. O yea, it has no choke assembly on it cause i got fed up tryin to make it work and just scrapped it all together
Old Apr 11, 2007 | 04:28 PM
2classics's Avatar
2classics
Does the truck hesitate when you try to accelerate? This sounds like power valve or accelerator pump possibly.
Old Apr 11, 2007 | 05:09 PM
Alvin in AZ's Avatar
Alvin in AZ
http://www.panix.com/~alvinj/file12/choke.jpg
Are we speaking the same language? :)
I'm not into 2150's tho ...just into 2100's. :/
SWAG... ok more of a WAG... sounds like you're too lean in the "low speed circuit".
Since it wasn't doing that before, sounds like some thing's plugging up one or both the low speed circuit jets? The low speed circuit jet is at the bottom-end of the small brass tube inside the larger emulsion tube. Which are all crammed into the bottom of the "booster assembly".
Using jet reamers i reamed my low speed circuit jets. It'll run pretty good without the accelerator pump hooked up even. So I have that set on the lowest hole.
Alvin in AZ
Old Apr 11, 2007 | 05:56 PM
Mil1ion's Avatar
Mil1ion
Hi and welcome to the site.
You will find info here
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
you will also get firsthand knowledge from Carb professionals in the FTE fuel delivery forum where Carburetor topics are best asked.
FTE is a huge site with system specific forums
So when you have a question on a topic... think about if it is a "Year specific" topic or "general system" topic.
Old Apr 11, 2007 | 06:38 PM
jasonr2210's Avatar
jasonr2210
sorry if i posted it in the wrong area. I was thinkin after readin that it may be to lean. has a small hesitation then a single pop thru the car then takes off.
