1978 - 1996 Big Bronco
system indicates rich
Old Jan 8, 2002 | 12:23 PM
Franklin2's Avatar
Franklin2
Right or wrong, I would try a regular pressure guage. It's for testing purposes only, and I would think a quality regular guage would handle it. I was wondering about this guage thing myself when I did this test, so I found a guage at work that they used for paint pressure pots. I figured if it could stand the solvents, it could stand gasoline, but I believe it was just a regular air guage. I took the guts out of the schrader valve on the fuel rail, and slipped a rubber hose over the fitting with a hose clamp. Like I said before, it's not like you are going to have to rely on this day after day, you will only have it on there for a short time for testing.
Old Jan 8, 2002 | 12:57 PM
Big Bronco Boy's Avatar
Big Bronco Boy
Old Jan 8, 2002 | 01:00 PM
chulsey12's Avatar
chulsey12
is there a fuel regulator on each fuel rail or just on the fuel rail that is visible
