shorty headers on 390 Fe
Old Apr 13, 2007 | 02:11 PM
Bear 45/70's Avatar
Bear 45/70
I had a set of shortie tri-Y's that I ran on a 428CJ back in the dark ages, I removed and threw away a set of the cast iron 427 manifolds (they weren't worth jack in 1969). Oh, what I wouldn't give to have those back now.
Old Apr 13, 2007 | 05:43 PM
jwtimme's Avatar
jwtimme
71_4x4_390 those 406 cast iron shorties will fit but a notch in the frame must be cut to allow clearence no hard I put a set on my 72.
Old Apr 13, 2007 | 09:43 PM
seetwisted's Avatar
seetwisted
Thumbs up almost...
I have the FF427 shortys on my truck. The FF390 looks shorter, and may even be better. When I built my pipes I had to start out with a fairly sharp turn from the collector to keep every thing up in the frame and not hanging down. Since the ff390 looks shorter,it may be easier to pipe...the other thing I did was to make a little heat shield out of exhaust pipe that mounted to the rear tube near the starter.It keeps the heat off the starter, I tack welded a couple of nuts to the tube and just screwed the heat shield on with a couple of short bolts. The air space in between lets the heat be carried away.
Old Apr 15, 2007 | 04:35 PM
71_4x4_390's Avatar
71_4x4_390
jwtimme:
Could you post some pictures of the cast headers on your truck showing the notch? The 72 looks very nice BTW
Old Apr 17, 2007 | 07:16 PM
jwtimme's Avatar
jwtimme
I added a pic to my gallery that shows the notch. needed to do a little updating anyway.
Old Apr 17, 2007 | 08:13 PM
71_4x4_390's Avatar
71_4x4_390
Thanks, I wonder if a 4x4 would be any different? any chance you could take a shot from the underside?
Old Apr 19, 2007 | 07:48 PM
jwtimme's Avatar
jwtimme
added a pic from under the truck hope it helps
Old Apr 19, 2007 | 08:47 PM
71_4x4_390's Avatar
71_4x4_390
Thanks,
I almost went with a white roof on my F250, but it had a two tone color scheme before so I went solid red.
Inches wise, how much frame was removed to give you the space to route the cast shorty? It looks like a 4x2.5" chunk from where I'm sitting.
Old Apr 22, 2007 | 12:52 PM
keisha9's Avatar
keisha9
im running the sanderson f428 its the fe HEADER AND I GOT IT COATED . OH BOY I LOVE EM AND U CANT BEAT THE QUALITY
Old Feb 8, 2010 | 08:30 AM
croof's Avatar
croof
Do you know if the sanderson shorty headers fo the FE 390 will fit a 76
Old Feb 8, 2010 | 04:25 PM
jowilker's Avatar
jowilker
croof, All the truck FEs are the same measurement, all the truck 2wd bays are the same from 65-76 that FEs were installed in.
In short I would say yes, but please wait for further.
John
Old Jan 3, 2011 | 07:03 PM
Adam K's Avatar
Adam K
I'm wondering if anyone has tried the sandersen headers in a low boy 77-79 f150 4x4 with a fe
Old Jan 3, 2011 | 10:12 PM
  #28
Steel Horse's Avatar
Steel Horse
Thanks for the tip on the Sanderson headers. Today I was trying to mount a set of full length Hedman Headers in the '59. They ALMOST made it.
Old Jul 26, 2011 | 12:37 AM
  #29
crazy96863's Avatar
crazy96863
I am looking to replace manifolds/exhaust on my 75 F-100 4x4... Looking for value but also proper fitting; none of this way below the frame stuff (preferably inside the frame though). At a glance the (Hedman headers PN 89120) look like they are it; do these pretty much follow the factory routing?
I have seen Flowtechs and Hookers around the same price if not slightly less; any objections or thoughts on what might best represent what I am looking for?
Planning on attaching them to a nice FlowMaster exhaust; again following the original dual exhaust path. Thanks!
Old Oct 18, 2011 | 10:22 PM
  #30
thunder31634's Avatar
thunder31634
I'm wondering the same thing. I have a 79 with a FE and long tube headers, now I can't get the front driveshaft in because it hits the collector.
