Engine Question
Old Apr 11, 2007 | 12:36 AM
White_Knuckles's Avatar
White_Knuckles
Engine Question
I have a knock coming from the passenger side of my 292. It has caused it to backfire when I put my foot into it rather severely. It also has blown the power valve in my Holley carb. What are some common problems that would cause this. I'm new with mechanical lifters and pushrods. Could it just have a loose rocker or a bent pushrod? There is around 8 to 10k on the motor.
Old Apr 11, 2007 | 01:08 AM
sierraben's Avatar
sierraben
I had the same problem with my 239 Y block some time back.
In my case, it turned out to be a bent pushrod.
My engine never got any oil to the heads (somewhat common with the Y blocks); so I had to pull over every few days, whip out the oil can, and oil the top of the rocker arm shafts.
Fomoko1's Avatar
Fomoko1
Sticking/burnt valve, timing?
Hopefully someone that knows will post.
Old Apr 11, 2007 | 08:19 AM
59flatbedford's Avatar
59flatbedford
could be a sticky valve or a bent pushrod. best bet would be to pull the valve covers
Old Apr 12, 2007 | 01:12 AM
White_Knuckles
What is the best place to get a pushrod for a 292?
Old Apr 12, 2007 | 05:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The answer to your unasked question is...all 292 pushrods are the same size: 1957-1964.
C0AE-6565-D .. Pushrod~Approx. 8.188" -length~one ball & one cup type ends.
BADASS 65 RANCHERO
Mar 27, 2014 12:33 PM
v8xploder
Feb 16, 2008 09:23 PM
jakemb
Mar 1, 2005 07:42 PM
1954blueoval
Jan 23, 2005 07:08 AM
fordman428
Aug 30, 2004 09:02 AM
