tranny,TC,or both??????
Old Apr 10, 2007 | 08:25 PM
pete98cobra's Avatar
pete98cobra
Question Help ...tranny,TC,or both??????
Need help. I was driving my 01 S.D. 7.3 home tonight. Made a right hand turn and felt a shift. Went to accelerate and started hearing a ticking noise. Made to my driveway. Started checking everything. Looks ok . Went out on a short trip .Truck bogged down like it started pulling something , then a shift and took off. started getting a slapping feel from under truck. . I then slowed down . Took off again and same thing happened again.
What could this be. I havent had transmission problems before. So this freaked me out.
Any help would be appreciated
Thanks,Pete
Old Apr 10, 2007 | 09:40 PM
aklim's Avatar
aklim
Did it feel like the E-brake was engaged suddenly? I had that and the fluid burnt even tho the temp didn't get over 180 degrees. Check the fluid.
Old Apr 10, 2007 | 11:00 PM
pete98cobra
checked fluid. ok . slight burnt smell. changed 15k miles ago
Old Apr 10, 2007 | 11:28 PM
white Buffalo's Avatar
white Buffalo
Can you feel the Torque Converter lock up in between 3rd & OD?
What do you tranny temps look like?
Does to OD light start flashing when you have problems?
Ford did have the Diode tranny made during certain months of 2001 that did have it's set of issues. Hey all you FTE guru's - anyone got the link to the dreaded diode tranny so he can check his out?
Old Apr 10, 2007 | 11:36 PM
pete98cobra
tranny temp, no temp gauge.
when I go to accelerate. goes fine then its like im pushing a load ,then its brakes loose, and then I hear a ticking sound ,and or a slapping sound from the bottom of the truck
did not notice OD light flashing
Old Apr 10, 2007 | 11:41 PM
white Buffalo
Send a PM to Casey. He is a tranny expert on this site and could help you out.
Click this link and you will see his post 1/2 way down the page (post #9). Left click his name and send him a PM.
https://www.ford-trucks.com/forums/6...ighlight=casey
Ford made the diode tranny the first 1/2 of 2001, but most problems seem to be with the 1-2 shift.
Old Apr 10, 2007 | 11:52 PM
mndiesel's Avatar
mndiesel
This may sound rediculas but what does a TC feel like when it LOCKS UP. I hear this all the time and am not sure what you are talking about!!!
Old Apr 10, 2007 | 11:53 PM
pete98cobra
thanks for the help W.B. .
I had already sent a PM to casey , but no reply yet. I did a serch , and someone else refered him for advice.
The other thing I noticed was. When I felt like I was pushing a load . I would let off the accelerator and it would go to the right. Without touching the brakes.
Old Apr 10, 2007 | 11:55 PM
white Buffalo
Basically it feels like another shift. While driving normally (not romping on it) you will feel the TC lock up around 40 mph. Starting from a stop, the 4R100 shifts like this:
1st
2nd
3rd
TC
OD
Old Apr 11, 2007 | 12:01 AM
pete98cobra
kinda feels like
no power motor revs
then like a thump
ticking and slapping noise
then let off accelerator
Old Apr 11, 2007 | 12:56 AM
mndiesel's Avatar
mndiesel
1st
2nd
3rd
TC
OD
Thanks alot. I will check it out tomorrow. This site rocks!!!!!!!!!!!!!!!!!
Old Apr 11, 2007 | 05:06 AM
aklim's Avatar
aklim
Originally Posted by pete98cobra
kinda feels like
no power motor revs
then like a thump
You can also call BTS and ask but I think you are looking at a new trans. Burnt fluid is NEVER a good sign.
Old Apr 12, 2007 | 05:53 PM
John311t's Avatar
John311t
Hmm, my truck when it used to shift from 3rd to 4th, it would all of a sudden feel like i was pushing something really hard, the motor would start to bog down R's and the trans temp went all the way to the right on my gauge, the 4th gear packs got welded together and got stuck on the side of the case causing nothing to move. Sounds like a trans problem.
Old Apr 12, 2007 | 07:04 PM
Kwikkordead's Avatar
Kwikkordead
kinda feels like
no power motor revs
then like a thump
That can't be good.
peter sipp
Jan 30, 2014 12:44 AM
kcode
Nov 9, 2013 07:55 PM
pete357
New Member Introductions
Dec 14, 2009 04:58 AM
Mad.Scientist
Aug 16, 2009 07:00 PM
throwdown
15
Mar 5, 2009 09:14 PM
