1978 - 1996 Big Bronco
Front Axle Replacement
Old Jan 10, 2002 | 12:12 AM
Franklin2's Avatar
Franklin2
Old Jan 12, 2002 | 12:02 AM
skipper's Avatar
skipper
I need help on how to remove the hub and rotor assembly from the steering knuckle. I already took off the locking hub and the spring clip around the axle as well as pulling out the small metal/rubber thingamabobs holding on the brake calipers. Does the caliper need to come off? How do you separate the hub/rotor assembly from the knuckle? I have an '86 Bronco with a badly shattered front axle and need to replace it so I can have my 4WD for winter.
