problem with trailer light plug
Old Apr 10, 2007 | 04:44 PM
Jtanner76's Avatar
Jtanner76
On my 96 F250, My towing harness has a 12 volt power supply when the ignition is on. When i was sevicing my travel trailer, i shorted something out. Now i cant get the power through the plug. I checked the fuses and fuseble links coming from the cylinoid. Any idea where the problem might be?
Old Apr 10, 2007 | 04:48 PM
Bruce R Leech's Avatar
Bruce R Leech
Did You Check The Fuses In The Power Distribution Box?
Old Apr 10, 2007 | 06:21 PM
sbowling79's Avatar
sbowling79
trailer tow battery charge is what the fuse is listed as
Old Apr 10, 2007 | 06:31 PM
Bruce R Leech
yes are you hot on both sides of that fuse? you dont have power on any of the connectors on the trailer plug? did you check the in cab fuse box? do you have a wiring diagram?
Old Apr 10, 2007 | 09:56 PM
Dryfire152's Avatar
Dryfire152
need more details, what is the something you shorted? Should be a fuse.
