need help
Old Apr 9, 2007 | 08:52 PM
rustee90-150's Avatar
rustee90-150
need help
i have a 90 150 302 the engine runs rough it performs fine it just has a little bounce to it when its idling i just bought a 91 f150 302 and the engine in it hardly bounces at all when its idling i dont understand it ive done a tuneup on my 90 new wires plugs cap rodor what is up
Old Apr 10, 2007 | 05:35 PM
12engine's Avatar
12engine
rustee, it might be a motor mount. if not, i dont know.
Old Apr 10, 2007 | 06:03 PM
Bruce R Leech's Avatar
Bruce R Leech
check the codes and post them here. it could be one of a hundred things so dont start replacing parts untill you have checked them and know that they are bad. we can help you with that, but first check the codes. and all connections and vacuum hoses
Old Apr 10, 2007 | 10:13 PM
Dryfire152's Avatar
Dryfire152
Check TPS, cracked plug,TFI, Did you use dialectric grease on plug wires. Also coil could be weak, if a plug has a wide gap, than a weak coil will not let the spark jump gap.
rustee90-150
24
Nov 16, 2011 08:05 AM
Orpackrat
Aerostar
15
Feb 17, 2010 11:21 PM
rustee90-150
May 5, 2007 02:05 PM
fordtrck302
25
Aug 19, 2005 04:05 PM
mag
Jan 4, 2001 09:33 PM
